Blackberry 7520 Motherboard Replacement
  1. Blackberry 7520 Motherboard Replacement, Battery: step 1, image 1 of 2 Blackberry 7520 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
    Ask FixBot
  2. Blackberry 7520 Motherboard Replacement: step 2, image 1 of 3 Blackberry 7520 Motherboard Replacement: step 2, image 2 of 3 Blackberry 7520 Motherboard Replacement: step 2, image 3 of 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
    Ask FixBot
  3. Blackberry 7520 Motherboard Replacement, Motherboard: step 3, image 1 of 2 Blackberry 7520 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
    Ask FixBot
  4. Blackberry 7520 Motherboard Replacement: step 4, image 1 of 2 Blackberry 7520 Motherboard Replacement: step 4, image 2 of 2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
    Ask FixBot
  5. Blackberry 7520 Motherboard Replacement: step 5, image 1 of 1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
    Ask FixBot
  6. Blackberry 7520 Motherboard Replacement: step 6, image 1 of 2 Blackberry 7520 Motherboard Replacement: step 6, image 2 of 2
    • Slide the rear panel forward to reveal the motherboard.
    Ask FixBot
  7. Blackberry 7520 Motherboard Replacement: step 7, image 1 of 2 Blackberry 7520 Motherboard Replacement: step 7, image 2 of 2
    • Remove the indicated screws using a T6 Torx screwdriver.
    Ask FixBot
  8. Blackberry 7520 Motherboard Replacement: step 8, image 1 of 2 Blackberry 7520 Motherboard Replacement: step 8, image 2 of 2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
    Ask FixBot
  9. Blackberry 7520 Motherboard Replacement: step 9, image 1 of 2 Blackberry 7520 Motherboard Replacement: step 9, image 2 of 2
    • Pull the metal plate away from the front panel of the cell phone.
    Ask FixBot
  10. Blackberry 7520 Motherboard Replacement: step 10, image 1 of 1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
    Ask FixBot
Nathan
31 Reputation
6 Guides authored
Cal Poly, Team 5-7, Forte Winter 2010 Member of Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 3,934
