Blackberry 7520 LCD Screen Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
30
All Time:
1,780
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
If you are removing or replacing the Blackberry 7520 LCD screen, look here for support.
Tools
    1. Blackberry 7520 LCD Screen Replacement, Battery: step 1, image 1 of 2 Blackberry 7520 LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Turn the phone upside down.
      • Push down on the black button on the back of the phone to slide the rear panel off.
      • The battery should be visible now.
      Ask FixBot
    2. Blackberry 7520 LCD Screen Replacement: step 2, image 1 of 3 Blackberry 7520 LCD Screen Replacement: step 2, image 2 of 3 Blackberry 7520 LCD Screen Replacement: step 2, image 3 of 3
      • Hold the BlackBerry in one hand face-up with the screen facing towards you.
      • Gently smack the phone against your hand to dislodge the battery.
      Ask FixBot
    1. Blackberry 7520 LCD Screen Replacement, Motherboard: step 3, image 1 of 2 Blackberry 7520 LCD Screen Replacement, Motherboard: step 3, image 2 of 2
      • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
      Ask FixBot
    2. Blackberry 7520 LCD Screen Replacement: step 4, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 4, image 2 of 2
      • Use a pick or plastic opening tool to push the clips holding the rear away from you.
      • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
      Ask FixBot
    3. Blackberry 7520 LCD Screen Replacement: step 5, image 1 of 1
      • Repeat the process of unlatching the clips for the top section of the Blackberry.
      Ask FixBot
    4. Blackberry 7520 LCD Screen Replacement: step 6, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 6, image 2 of 2
      • Slide the rear panel forward to reveal the motherboard.
      Ask FixBot
    5. Blackberry 7520 LCD Screen Replacement: step 7, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 7, image 2 of 2
      • Remove the indicated screws using a T6 Torx screwdriver.
      Ask FixBot
    6. Blackberry 7520 LCD Screen Replacement: step 8, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 8, image 2 of 2
      • Remove the motherboard.
      • Remove the indicated screw using the T6 Torx screwdriver.
      Ask FixBot
    7. Blackberry 7520 LCD Screen Replacement: step 9, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 9, image 2 of 2
      • Pull the metal plate away from the front panel of the cell phone.
      Ask FixBot
    8. Blackberry 7520 LCD Screen Replacement: step 10, image 1 of 1
      • Place the faceplate face-down and the interior of the phone face-up, as shown.
      Ask FixBot
    1. Blackberry 7520 LCD Screen Replacement, LCD Screen: step 11, image 1 of 1
      • Turn the phone so that it faces towards you.
      Ask FixBot
    2. Blackberry 7520 LCD Screen Replacement: step 12, image 1 of 1
      • Use a pick or other small tool to pop the small plastic clip holding the LCD panel on
      Ask FixBot
    3. Blackberry 7520 LCD Screen Replacement: step 13, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 13, image 2 of 2
      • Pull the LCD screen off of the board.
      Ask FixBot
Nathan
31 Reputation
6 Guides authored
Cal Poly, Team 5-7, Forte Winter 2010 Member of Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Members
72 Guides authored
1 Guide Comment
It’s too bad that iFixit didn’t post a teardown listing the parts for the BlackBerry 7520, since so little is known about its parts.
amosbatto - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,780
