Blackberry 7520 Keypad Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
29
All Time:
1,675
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
If you are removing the keypad to clean or replace it, this guide is for you.
Tools
    1. Blackberry 7520 Keypad Replacement, Battery: step 1, image 1 of 2 Blackberry 7520 Keypad Replacement, Battery: step 1, image 2 of 2
      • Turn the phone upside down.
      • Push down on the black button on the back of the phone to slide the rear panel off.
      • The battery should be visible now.
      Ask FixBot
    2. Blackberry 7520 Keypad Replacement: step 2, image 1 of 3 Blackberry 7520 Keypad Replacement: step 2, image 2 of 3 Blackberry 7520 Keypad Replacement: step 2, image 3 of 3
      • Hold the BlackBerry in one hand face-up with the screen facing towards you.
      • Gently smack the phone against your hand to dislodge the battery.
      Ask FixBot
    1. Blackberry 7520 Keypad Replacement, Motherboard: step 3, image 1 of 2 Blackberry 7520 Keypad Replacement, Motherboard: step 3, image 2 of 2
      • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
      Ask FixBot
    2. Blackberry 7520 Keypad Replacement: step 4, image 1 of 2 Blackberry 7520 Keypad Replacement: step 4, image 2 of 2
      • Use a pick or plastic opening tool to push the clips holding the rear away from you.
      • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
      Ask FixBot
    3. Blackberry 7520 Keypad Replacement: step 5, image 1 of 1
      • Repeat the process of unlatching the clips for the top section of the Blackberry.
      Ask FixBot
    4. Blackberry 7520 Keypad Replacement: step 6, image 1 of 2 Blackberry 7520 Keypad Replacement: step 6, image 2 of 2
      • Slide the rear panel forward to reveal the motherboard.
      Ask FixBot
    5. Blackberry 7520 Keypad Replacement: step 7, image 1 of 2 Blackberry 7520 Keypad Replacement: step 7, image 2 of 2
      • Remove the indicated screws using a T6 Torx screwdriver.
      Ask FixBot
    6. Blackberry 7520 Keypad Replacement: step 8, image 1 of 2 Blackberry 7520 Keypad Replacement: step 8, image 2 of 2
      • Remove the motherboard.
      • Remove the indicated screw using the T6 Torx screwdriver.
      Ask FixBot
    7. Blackberry 7520 Keypad Replacement: step 9, image 1 of 2 Blackberry 7520 Keypad Replacement: step 9, image 2 of 2
      • Pull the metal plate away from the front panel of the cell phone.
      Ask FixBot
    8. Blackberry 7520 Keypad Replacement: step 10, image 1 of 1
      • Place the faceplate face-down and the interior of the phone face-up, as shown.
      Ask FixBot
    1. Blackberry 7520 Keypad Replacement, Keypad: step 11, image 1 of 2 Blackberry 7520 Keypad Replacement, Keypad: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • After removing the faceplate of the BlackBerry, place it facing down on a table as shown.
      • Using tweezers if needed, grip the keypad by one of the plastic nubs and pull it off of the pins.
      • Alternatively, you can pop the keypad out by holding the faceplate face-up and pressing the keys down. Be sure to catch the keypad when it falls out.
      Ask FixBot
    2. Blackberry 7520 Keypad Replacement: step 12, image 1 of 1
      • If you are cleaning the keypad, use a fine brush to wipe any dirt from both the front and back of the pad.
      • You may also rinse the keypad with water, but make sure that it is completely dry before reinserting it on to the faceplate.
      Ask FixBot
    3. Blackberry 7520 Keypad Replacement: step 13, image 1 of 1
      • To place the new or cleaned keypad in the faceplate, hold the faceplate in one hand face-down and grab the keypad by the edges in your other hand.
      • Align the holes in the keypad over the black pins in the faceplate and press down on the keypad until it is firmly in place. Flip the faceplate over to make sure that the keys are properly aligned.
      Ask FixBot
Nathan
31 Reputation
6 Guides authored
Cal Poly, Team 5-7, Forte Winter 2010 Member of Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,675
