Blackberry 7105t Disassembly
    1. Blackberry 7105t Disassembly, Blackberry 7105t Disassembly: step 1, image 1 of 1
      • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
      Ask FixBot
    2. Blackberry 7105t Disassembly: step 2, image 1 of 1
      • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
      Ask FixBot
    3. Blackberry 7105t Disassembly: step 3, image 1 of 1
      • Remove the battery by pushing against it from the right and then pulling towards you.
      Ask FixBot
    4. Blackberry 7105t Disassembly: step 4, image 1 of 1
      • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
      Ask FixBot
    5. Blackberry 7105t Disassembly: step 5, image 1 of 3 Blackberry 7105t Disassembly: step 5, image 2 of 3 Blackberry 7105t Disassembly: step 5, image 3 of 3
      • Use a plastic opening tool or your fingernails to remove the plastic backing.
      • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
      Ask FixBot
    6. Blackberry 7105t Disassembly: step 6, image 1 of 1
      • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
      • Place the four screws released from the phone in a plastic bag.
      Ask FixBot
    7. Blackberry 7105t Disassembly: step 7, image 1 of 1
      • The black battery casing and logic board can now be separated for the following steps.
      Ask FixBot
kelogan
1 Reputation
2 Guides authored
Cal Poly, Team 9-17, Regan Fall 2009 Member of Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 14
All Time: 2,456
