BlackBerry Z30 Logic board Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
93
All Time:
4,716
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Parts
Tools
    1. BlackBerry Z30 Logic board Replacement, Battery cover: step 1, image 1 of 1
      • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
      Ask FixBot
    2. BlackBerry Z30 Logic board Replacement, Remove SIM and Media Card: step 2, image 1 of 1
      • Remove the SIM card and the Media SD card by pushing on them.
      Ask FixBot
    3. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: step 3, image 1 of 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: step 3, image 2 of 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: step 3, image 3 of 3
      • Locate and unscrew all 10 T5 screws around the back cover
      Ask FixBot
    4. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: step 4, image 1 of 2 BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: step 4, image 2 of 2
      • Use Plastic opening tools to separate the LCD from the Main body
      • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
      • Start on the same side of the Audio Jack
      Ask FixBot
    5. BlackBerry Z30 Logic board Replacement, Remove the LCD: step 5, image 1 of 2 BlackBerry Z30 Logic board Replacement, Remove the LCD: step 5, image 2 of 2
      • Use a plastic tool to carefully switch up the LCD ribbon holder
      • Detach the LCD from the main board
      • When installing the new LCD, make sure the ribbon is inserted to the white line.
      Ask FixBot
    6. BlackBerry Z30 Logic board Replacement, LCD Panel removal: step 6, image 1 of 1
      • You can now detach the LCD Panel from the main frame.
      Ask FixBot
    1. BlackBerry Z30 Logic board Replacement, Untie the System board: step 7, image 1 of 1
      • With a plastic tool, untie the system board by detaching the ribbons attached to it
      • The battery ribbon is on the bottom right
      • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
      Ask FixBot
    2. BlackBerry Z30 Logic board Replacement, Untie the System board Part 2: step 8, image 1 of 1
      • Be gentle as any other system board ribbons, they are very easy to damage
      Ask FixBot
    3. BlackBerry Z30 Logic board Replacement, Untie the system board Part 3: step 9, image 1 of 1
      • Power Button /Audio Jack
      • Flash
      • Rear Facing Camera
      Ask FixBot
    4. BlackBerry Z30 Logic board Replacement, System board removal: step 10, image 1 of 1
      • Once all Ribbons untied, gently wiggle the system board out of the frame
      • Do not pull hard as there might be a ribbon on the way
      Ask FixBot
4 other people completed this guide.
Hans
1,947 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 93
All Time: 4,716
