BlackBerry World Edition 8830 Trackball Replacement
  1. BlackBerry World Edition 8830 Trackball Replacement, Trackball: step 1, image 1 of 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: step 1, image 2 of 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: step 1, image 3 of 3
    • Make sure the phone is powered off before removing the trackball.
    • Gently use the Small Flathead Screwdriver or plastic opening tool to go under the chrome ring surrounding the trackball.
    • Pry the chrome ring upwards with the tool until it begins to lift up.
    • Once it begins to lift up, gently remove the chrome ring from around the trackball.
    • When re-assembling the phone, be sure to orient the chrome ring so that the missing tab is at the top.
    Ask FixBot
  2. BlackBerry World Edition 8830 Trackball Replacement: step 2, image 1 of 2 BlackBerry World Edition 8830 Trackball Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • After removing the chrome ring, slowly lift up the remaining piece with tweezers.
    • Slowly remove the small plastic bottom using the Plastic Opener tool. Be careful not to bend the metal frame when removing the bottom plastic piece.
    • Using your hands, remove the white plastic piece, revealing the small metal frame, the scroll wheels, and the trackball.
    Ask FixBot
  3. BlackBerry World Edition 8830 Trackball Replacement: step 3, image 1 of 1
    • Slowly remove the trackball, being cautious not to scratch the ball or the scroll wheels.
    • Using a soft cloth, carefully remove any dust around the scroll wheels or the trackball itself.
    • While the trackball is removed, you may clean the sensor in the hole where the trackball is usually located.
    Ask FixBot
tbace
28 Reputation
2 Guides authored
Cal Poly, Team 17-27, Amido Spring 2012 Member of Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 50
All Time: 1,594
