Turn phone over to the backside.
Press down on the lower portion of the back cover.
Slide the lower portion down to remove the cover and reveal the battery.
Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
Once the microphone is revealed, use the flathead screwdriver, or the tip of a knife, to carefully pry the microphone out of the hole.
