BlackBerry Torch 9850 Sim card reader Replacement
  1. BlackBerry Torch 9850 Sim card reader Replacement, Display: step 1, image 1 of 3 BlackBerry Torch 9850 Sim card reader Replacement, Display: step 1, image 2 of 3 BlackBerry Torch 9850 Sim card reader Replacement, Display: step 1, image 3 of 3
    • Remove the battery.
    • Use a plastic spudger tool or your fingers to gently pop the battery out from the bottom by pushing and lifting.
    Ask FixBot
  2. BlackBerry Torch 9850 Sim card reader Replacement: step 2, image 1 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 2, image 2 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 2, image 3 of 3
    • Removing the sim card.
    • Press and pull down on the yellow tab until the sim card falls out.
    Ask FixBot
  3. BlackBerry Torch 9850 Sim card reader Replacement: step 3, image 1 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 3, image 2 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 3, image 3 of 3
    • Remove the plastic bezle.
    • To remove the plastic bezle on the back of the phone, use a plastic prying tool to gently pry it off.
    • Begin in the center on the bottom of the phone, and slowly work your way around to each side.
    • Once the bezle is loosened on both sides, you can gently pull it off with your hands.
    Ask FixBot
  4. BlackBerry Torch 9850 Sim card reader Replacement: step 4, image 1 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 4, image 2 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 4, image 3 of 3
    • Remove the screws.
    • You will need to remove the ten small screws that hold the back of the phone together.
    • Start by using a T5 phillips screw driver to remove the four 4.5 mm screws on the outside corners of the phone.
    • Next, use a T4 phillips screw driver to remove the four 4mm screws on the sides of the device.
    • Lastly, use the T4 phillips screw driver again to remove the last of the screws, which should be two 2mm screws on the bottom.
    Ask FixBot
  5. BlackBerry Torch 9850 Sim card reader Replacement: step 5, image 1 of 2 BlackBerry Torch 9850 Sim card reader Replacement: step 5, image 2 of 2
    • Remove the back piece.
    • Once you have all the screws removed, gently remove the back piece of the phone with your hands.
    • Do not pull the back of the phone all the way off, because there are cable ribbons that will break if you do.
    Ask FixBot
  6. BlackBerry Torch 9850 Sim card reader Replacement: step 6, image 1 of 2 BlackBerry Torch 9850 Sim card reader Replacement: step 6, image 2 of 2
    • Disconnect the main cable ribbon.
    • There will be a black cable ribbon on the upper right side of the phone.
    • Using the metal pry tool, gently pry this cable ribbon open to separate the front and back pieces of the phone.
    Ask FixBot
  7. BlackBerry Torch 9850 Sim card reader Replacement: step 7, image 1 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 7, image 2 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 7, image 3 of 3
    • Disconnect the remaining cable ribbons.
    • There are two copper cable ribbons.
    • Using a metal pry tool, carefully disconnect the first copper cable ribbon on the bottom right side of the phone.
    • Likewise, disconnect the square copper cable ribbon at the top right of the phone.
    • Once you disconnect the first square cable ribbon, a second will be exposed and you can disconnect that one the same way.
    Ask FixBot
  8. BlackBerry Torch 9850 Sim card reader Replacement: step 8, image 1 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 8, image 2 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 8, image 3 of 3
    • Remove the LCD screen.
    • Once you have completed all of the previous steps, you can remove the display.
    • Gently pry on the little tab at the top of the screen to remove it.
    Ask FixBot
  9. BlackBerry Torch 9850 Sim card reader Replacement, Sim card reader: step 9, image 1 of 2 BlackBerry Torch 9850 Sim card reader Replacement, Sim card reader: step 9, image 2 of 2
    • Remove the four screws from the sim card reader.
    • Remove the 1mm screw using a T5 phillips screwdriver.
    • Remove the three 3mm screws also using a T5 phillips screwdriver.
    Ask FixBot
  10. BlackBerry Torch 9850 Sim card reader Replacement: step 10, image 1 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 10, image 2 of 3 BlackBerry Torch 9850 Sim card reader Replacement: step 10, image 3 of 3
    • Remove the sim card reader.
    • Use the metal pry tool to gently remove the sim card reader.
    Ask FixBot
2 other people completed this guide.
Rachel Staigerwald
712 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 1,227
