BlackBerry Torch 9850 Battery Replacement
  1. BlackBerry Torch 9850 Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure the device is disconnected from any charging cables
    • Press and hold down the power/end button on the phone until phone powers off and the screen goes black. Locate the power button on the lower-right face of the device
    • Press and hold the power button until the display shuts down and the screen remains completely black
    Ask FixBot
  2. BlackBerry Torch 9850 Battery Replacement: step 2, image 1 of 2 BlackBerry Torch 9850 Battery Replacement: step 2, image 2 of 2
    • Locate the batter cover release button at the bottom of the devices's rear panel
    • Press and hold the release button while simultaneously lifting the battery cover away from the chassis
    • Remove the cover completely and set it aside in a safe location
    Ask FixBot
  3. BlackBerry Torch 9850 Battery Replacement: step 3, image 1 of 3 BlackBerry Torch 9850 Battery Replacement: step 3, image 2 of 3 BlackBerry Torch 9850 Battery Replacement: step 3, image 3 of 3
    • Remove the battery.
    • Once the plastic covering is removed, you can remove the battery.
    • Use your fingers or a plastic spudger to pop the bottom of the battery out of its place by pushing and lifting.
    • Once the bottom of the battery has ejected, you can easily remove the whole battery from the phone with your hands.
    Ask FixBot
  4. BlackBerry Torch 9850 Battery Replacement: step 4, image 1 of 2 BlackBerry Torch 9850 Battery Replacement: step 4, image 2 of 2
    • Inserting a new battery.
    • Align the plus and minus signs at the top of the battery compartment with the plus and minus signs at the top of the battery.
    • Push battery into place.
    • Replace the plastic cover by snapping into place.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Rachel Staigerwald
712 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 45
All Time: 1,066
