Introduction
Follow this guide to remove the logic board.
Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
One is located below the scrollwheel.
Another is located behind the screen.
Pinch the white plastic clip that connects the ribbon of the scroll wheel to the logic board.
Gently wiggle and pull upwards to remove the scroll wheel.
Pull out the two black clips securing the screen’s ribbon so that they are as far out as they will go.
Gently remove the screen’s ribbon from the slot. Be sure to support the screen and any connected parts.
Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
Gently pull on the wires connecting the battery to the device until the battery disconnects.
