BlackBerry Pearl 8100 Screen Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
86
All Time:
3,505
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Use this repair guide to install the screen in the Blackberry Pearl 8100
Tools
    1. BlackBerry Pearl 8100 Screen Replacement, Battery: step 1, image 1 of 1
      • Before working on the phone, be sure that the device is turned off.
      • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
      Ask FixBot
      • Remove the battery located directly below back panel.
      Ask FixBot
    1. BlackBerry Pearl 8100 Screen Replacement, Keyboard: step 3, image 1 of 1
      • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
      Ask FixBot
    2. BlackBerry Pearl 8100 Screen Replacement: step 4, image 1 of 2 BlackBerry Pearl 8100 Screen Replacement: step 4, image 2 of 2
      • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
      Ask FixBot
    3. BlackBerry Pearl 8100 Screen Replacement: step 5, image 1 of 1
      • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
      Ask FixBot
    4. BlackBerry Pearl 8100 Screen Replacement: step 6, image 1 of 1
      • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
      Ask FixBot
    5. BlackBerry Pearl 8100 Screen Replacement: step 7, image 1 of 2 BlackBerry Pearl 8100 Screen Replacement: step 7, image 2 of 2
      • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
      Ask FixBot
    6. BlackBerry Pearl 8100 Screen Replacement: step 8, image 1 of 1
      • Separate the logic board from the front panel.
      Ask FixBot
    7. BlackBerry Pearl 8100 Screen Replacement: step 9, image 1 of 2 BlackBerry Pearl 8100 Screen Replacement: step 9, image 2 of 2
      • Gently remove the keyboard from front casing. It should snap out of place.
      Ask FixBot
    1. BlackBerry Pearl 8100 Screen Replacement, Screen: step 10, image 1 of 1
      • After removing the logic board, place spudger between the logic board and screen and remove the screen, sliding it slowly away.
      Ask FixBot
2 other people completed this guide.
Robert Cronin
544 Reputation
6 Guides authored
Cal Poly, Team 34-57, Forte Spring 2010 Member of Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 86
All Time: 3,505
