BlackBerry Passport Battery Replacement
  1. BlackBerry Passport Battery Replacement, Motherboard: step 1, image 1 of 3 BlackBerry Passport Battery Replacement, Motherboard: step 1, image 2 of 3 BlackBerry Passport Battery Replacement, Motherboard: step 1, image 3 of 3
    • Flip the phone on its front.
    Ask FixBot
  2. BlackBerry Passport Battery Replacement: step 2, image 1 of 2 BlackBerry Passport Battery Replacement: step 2, image 2 of 2
    • Remove the top SIM/microSD card cover by the notch.
    Ask FixBot
  3. BlackBerry Passport Battery Replacement: step 3, image 1 of 1
    • Remove the top two 7 mm screws using a T4 Torx screwdriver.
    • Remove the bottom three 5 mm screws using a T4 Torx screwdriver.
    Ask FixBot
  4. BlackBerry Passport Battery Replacement: step 4, image 1 of 3 BlackBerry Passport Battery Replacement: step 4, image 2 of 3 BlackBerry Passport Battery Replacement: step 4, image 3 of 3
    • Flip the phone to its back.
    Ask FixBot
  5. BlackBerry Passport Battery Replacement: step 5, image 1 of 3 BlackBerry Passport Battery Replacement: step 5, image 2 of 3 BlackBerry Passport Battery Replacement: step 5, image 3 of 3
    • Remove the cover located under the keyboard.
    Ask FixBot
  6. BlackBerry Passport Battery Replacement: step 6, image 1 of 1
    • Remove the two 6 mm screws using the T4 Torx screwdriver.
    Ask FixBot
  7. BlackBerry Passport Battery Replacement: step 7, image 1 of 3 BlackBerry Passport Battery Replacement: step 7, image 2 of 3 BlackBerry Passport Battery Replacement: step 7, image 3 of 3
    Ask FixBot
  8. BlackBerry Passport Battery Replacement: step 8, image 1 of 3 BlackBerry Passport Battery Replacement: step 8, image 2 of 3 BlackBerry Passport Battery Replacement: step 8, image 3 of 3
    • Remove the back cover.
    Ask FixBot
  9. BlackBerry Passport Battery Replacement: step 9, image 1 of 3 BlackBerry Passport Battery Replacement: step 9, image 2 of 3 BlackBerry Passport Battery Replacement: step 9, image 3 of 3
    • Remove the black tape from the battery and the motherboard.
    Ask FixBot
  10. BlackBerry Passport Battery Replacement: step 10, image 1 of 1
    • Remove the five 4 mm screws using a T4 Torx screwdriver.
    • Remove the two 3 mm screws using a T4 Torx screwdriver.
    Ask FixBot
  11. BlackBerry Passport Battery Replacement: step 11, image 1 of 1
    • Disconnect the left four connectors.
    Ask FixBot
  12. BlackBerry Passport Battery Replacement: step 12, image 1 of 3 BlackBerry Passport Battery Replacement: step 12, image 2 of 3 BlackBerry Passport Battery Replacement: step 12, image 3 of 3
    • Remove the motherboard.
    Ask FixBot
  13. BlackBerry Passport Battery Replacement, Battery: step 13, image 1 of 3 BlackBerry Passport Battery Replacement, Battery: step 13, image 2 of 3 BlackBerry Passport Battery Replacement, Battery: step 13, image 3 of 3
    • Remove the battery.
    • The battery might be glued in its place.
    • Be careful not to puncture the battery; it can cause fires, explosions, and other serious hazards!
    Ask FixBot
2 other people completed this guide.
Elena Santana
221 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 79
All Time: 966
