Up to 20% off select tools
BlackBerry KeyONE partial Disassembly
Views: 11K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
121
All Time:
11,376
Comments: 0
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. BlackBerry KeyONE partial Disassembly, Remove top cover: step 1, image 1 of 1
      • Carefully remove the top plastic cover. It is held in place by adhesive.
      Ask FixBot
    2. BlackBerry KeyONE partial Disassembly, Remove top frame: step 2, image 1 of 2 BlackBerry KeyONE partial Disassembly, Remove top frame: step 2, image 2 of 2
      • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
      Ask FixBot
    3. BlackBerry KeyONE partial Disassembly, Remove back cover: step 3, image 1 of 1
      • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
      Ask FixBot
    4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: step 4, image 1 of 2 BlackBerry KeyONE partial Disassembly, Disconnect Battery: step 4, image 2 of 2
      • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
      Ask FixBot
    5. BlackBerry KeyONE partial Disassembly: step 5, image 1 of 1
      • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
      • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
      Ask FixBot
    6. BlackBerry KeyONE partial Disassembly, Remove top cover: step 6, image 1 of 1
      • Remove the three Philipps #0 screws securing the upper cover and remove it.
      Ask FixBot
    7. BlackBerry KeyONE partial Disassembly: step 7, image 1 of 1
      • Unplug the remaining ribbon cables
      • Remove the last three Philipps #0 screws securing the Motherbard.
      • Now you should be able to replace most components.
      • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
      • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
      • Don't forget to remove the sim-tray if you're removing the motherboard.
      Ask FixBot
15 other people completed this guide.
Author
with
raven
1,110 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 121
All Time: 11,376
