Up to 20% off select tools
BlackBerry Key2 Disassembly
Views: 19K
View statistics:
Past 24 Hours:
Past 7 Days:
42
Past 30 Days:
227
All Time:
19,189
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. BlackBerry Key2 Disassembly, Blackberry Key2: step 1, image 1 of 3 BlackBerry Key2 Disassembly, Blackberry Key2: step 1, image 2 of 3 BlackBerry Key2 Disassembly, Blackberry Key2: step 1, image 3 of 3
      • The start of our disassembly. Turn off your device before start.
      • Remove the sim card bracket.
      Ask FixBot
    2. BlackBerry Key2 Disassembly, Heating process: step 2, image 1 of 3 BlackBerry Key2 Disassembly, Heating process: step 2, image 2 of 3 BlackBerry Key2 Disassembly, Heating process: step 2, image 3 of 3
      • Apply heat to the back of the phone to remove the plastic cover.
      • With a pry tool of your preference start to lift up the back cover. Be careful on that part of the process.
      Ask FixBot
    3. BlackBerry Key2 Disassembly, Removing the screws: step 3, image 1 of 3 BlackBerry Key2 Disassembly, Removing the screws: step 3, image 2 of 3 BlackBerry Key2 Disassembly, Removing the screws: step 3, image 3 of 3
      • Remove all the screws.
      • Remove the loudspeaker module.
      Ask FixBot
    4. BlackBerry Key2 Disassembly, Antenna cable: step 4, image 1 of 3 BlackBerry Key2 Disassembly, Antenna cable: step 4, image 2 of 3 BlackBerry Key2 Disassembly, Antenna cable: step 4, image 3 of 3
      • Use the point of a plastic spudger to lift the antenna cable connector up off of its socket on the logic board.
      Ask FixBot
    5. BlackBerry Key2 Disassembly, Back bracket: step 5, image 1 of 3 BlackBerry Key2 Disassembly, Back bracket: step 5, image 2 of 3 BlackBerry Key2 Disassembly, Back bracket: step 5, image 3 of 3
      • Be gentle lifting up the back bracket.
      • I marked in red all the flex cables connected on the motherboard. You got to remove them all.
      • Start disconnecting the battery flex cable.
      Ask FixBot
    6. BlackBerry Key2 Disassembly, Removing the flex cables: step 6, image 1 of 3 BlackBerry Key2 Disassembly, Removing the flex cables: step 6, image 2 of 3 BlackBerry Key2 Disassembly, Removing the flex cables: step 6, image 3 of 3
      • Disconnect and remove the rear camera.
      • Then continue disconnecting the other flex cables.
      • Don't forget to use a plastic tool.
      Ask FixBot
    7. BlackBerry Key2 Disassembly, Removing the motherboard.: step 7, image 1 of 3 BlackBerry Key2 Disassembly, Removing the motherboard.: step 7, image 2 of 3 BlackBerry Key2 Disassembly, Removing the motherboard.: step 7, image 3 of 3
      • Disconnect all the flex cables.
      • Start from the bottom .
      • Lift up gentle and check the last photo,there's a little detail on the proximity sensor. You'll have to disconnect it after lift up the motherboard.
      • Observation : this way worked better for me without damaging the proximity sensor. It doesn't change anything try to heat up a little bit and removing it before remove the motherboard.
      Ask FixBot
    8. BlackBerry Key2 Disassembly, Removing the LCD.: step 8, image 1 of 3 BlackBerry Key2 Disassembly, Removing the LCD.: step 8, image 2 of 3 BlackBerry Key2 Disassembly, Removing the LCD.: step 8, image 3 of 3
      • Heat the LCD before lift.
      Ask FixBot
    9. BlackBerry Key2 Disassembly, Final: step 9, image 1 of 1
      • And we're done.
      Ask FixBot
15 other people completed this guide.
Author
with
DouglasVinicio
1,711 Reputation
1 Guide authored
4 Guide Comments
The antenna connector on the daughter board can be broken off really easily. Pop off the connectors carefully. A hot air workstation will make quick work of re attaching tho.
Grant Marshall - Reply Share
OMG that’s probably exactly what happened to me. now the phone does not receive network anymore any suggestions on what to do ?? i am quite certain i cannot get another antenna or board. do you think i can find a matching antenna from another phone entirely ???
Chinedu - Reply Share
Thanks for this tear down! At what step can the battery be removed? It *appears* to be mid-step-5
charleslindsay - Reply Share
Same her no Network so my Key2 ist useless :/
Christoph Alber - Reply Share
Past 24 Hours: 1
Past 7 Days: 42
Past 30 Days: 227
All Time: 19,189
