BlackBerry Curve 8900 Screen Replacement
    1. BlackBerry Curve 8900 Screen Replacement, Screen: step 1, image 1 of 1
      • Open the rear panel to expose the battery and the chassis assembly. Remove the battery.
      Ask FixBot
    2. BlackBerry Curve 8900 Screen Replacement: step 2, image 1 of 1
      • Use a small, non-marring plastic opening tool to remove the lower-rear cover. (Credit cards and guitar picks work great.)
      Ask FixBot
    3. BlackBerry Curve 8900 Screen Replacement: step 3, image 1 of 1
      • Use a T6 Torx screwdriver to loosen and remove the six screws from the chassis as shown.
      • Flip the phone over to the front and remove the plastic bezel.
      Ask FixBot
    4. BlackBerry Curve 8900 Screen Replacement: step 4, image 1 of 1
      • Remove the midframe from the back of the phone, which should now be free after removing the screws. The green motherboard should now be exposed.
      Ask FixBot
    5. BlackBerry Curve 8900 Screen Replacement: step 5, image 1 of 1
      • Remove the front-cover by carefully prying the side release tabs, located on the side of the phone.
      Ask FixBot
    6. BlackBerry Curve 8900 Screen Replacement: step 6, image 1 of 3 BlackBerry Curve 8900 Screen Replacement: step 6, image 2 of 3 BlackBerry Curve 8900 Screen Replacement: step 6, image 3 of 3
      • Gently pry the side release tabs to lift the flexing keypad from the frame.
      • The navigation ball may come loose at this point. Set it aside with the keypad for reassembly.
      Ask FixBot
    7. BlackBerry Curve 8900 Screen Replacement: step 7, image 1 of 1
      • Gently lift the motherboard.
      • Locate the screen's ribbon cable underneath the motherboard, and detach it from the phone.
      Ask FixBot
    8. BlackBerry Curve 8900 Screen Replacement: step 8, image 1 of 2 BlackBerry Curve 8900 Screen Replacement: step 8, image 2 of 2
      • Carefully pry at the sides of the screen until the display assembly is free. Remove the display from the motherboard unit.
      Ask FixBot
4 other people completed this guide.
Renae Bishop
68 Reputation
4 Guides authored
Cuesta, Team 1-3, Zipperian Fall 2011 Member of Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 4,801
