BlackBerry Curve 8900 Microphone Replacement
    1. BlackBerry Curve 8900 Microphone Replacement, Microphone: step 1, image 1 of 1
      • Press and slide the battery cover from the back of the device with your fingers.
      • Remove the battery by pulling it out.
      • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
      Ask FixBot
    2. BlackBerry Curve 8900 Microphone Replacement: step 2, image 1 of 1
      Tool used on this step:
      iFixit Opening Tool
      $1.99
      Buy
      • Using the iFixit Opening Tool, remove the lower rear cover.
      Ask FixBot
    3. BlackBerry Curve 8900 Microphone Replacement: step 3, image 1 of 1
      T6 Torx Screwdriver
      $9.99
      Buy
      Ask FixBot
    4. BlackBerry Curve 8900 Microphone Replacement: step 4, image 1 of 1
      iFixit Opening Tool
      $1.99
      Buy
      Ask FixBot
    5. BlackBerry Curve 8900 Microphone Replacement: step 5, image 1 of 2 BlackBerry Curve 8900 Microphone Replacement: step 5, image 2 of 2
      • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
      Ask FixBot
    6. BlackBerry Curve 8900 Microphone Replacement: step 6, image 1 of 1
      • With your fingers, carefully remove the screen so as not to damage it.
      Ask FixBot
    7. BlackBerry Curve 8900 Microphone Replacement: step 7, image 1 of 2 BlackBerry Curve 8900 Microphone Replacement: step 7, image 2 of 2
      • With your fingers, carefully unhook the antenna cable in all three locations.
      Ask FixBot
    8. BlackBerry Curve 8900 Microphone Replacement: step 8, image 1 of 1
      Spudger
      $3.99
      Buy
      • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
      Ask FixBot
    9. BlackBerry Curve 8900 Microphone Replacement: step 9, image 1 of 1
      • Detach the motherboard from both ribbon connections.
      • The ribbon connections are indicated by red circles on the photograph.
      • The ribbon connections are indicated by orange rectangles on the photograph.
      Ask FixBot
    10. BlackBerry Curve 8900 Microphone Replacement: step 10, image 1 of 2 BlackBerry Curve 8900 Microphone Replacement: step 10, image 2 of 2
      • Replace the entire motherboard to replace the microphone.
      Ask FixBot
Johnny Tran
473 Reputation
4 Guides authored
Cuesta, Team 1-3, Zipperian Fall 2011 Member of Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 26
All Time: 4,897
