BlackBerry Curve 8530 Trackpad Replacement
    1. BlackBerry Curve 8530 Trackpad Replacement, Battery: step 1, image 1 of 2 BlackBerry Curve 8530 Trackpad Replacement, Battery: step 1, image 2 of 2
      • Place the phone on a flat surface with the screen facing down.
      • Remove the plastic backplate by pulling up on the bottom of the cover.
      Ask FixBot
    2. BlackBerry Curve 8530 Trackpad Replacement: step 2, image 1 of 1
      • Remove the battery by pulling up from the top of the battery.
      Ask FixBot
    1. BlackBerry Curve 8530 Trackpad Replacement, Keypad: step 3, image 1 of 2 BlackBerry Curve 8530 Trackpad Replacement, Keypad: step 3, image 2 of 2
      • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
      • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
      Ask FixBot
    2. BlackBerry Curve 8530 Trackpad Replacement: step 4, image 1 of 2 BlackBerry Curve 8530 Trackpad Replacement: step 4, image 2 of 2
      • Flip the phone over so the keyboard faces up.
      • Insert a plastic spudger into the screen where speaker resides.
      • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
      • Gently lift up plastic screen cover until screen cover separates from screen.
      • Continue until screen cover is completely removed.
      Ask FixBot
    3. BlackBerry Curve 8530 Trackpad Replacement: step 5, image 1 of 3 BlackBerry Curve 8530 Trackpad Replacement: step 5, image 2 of 3 BlackBerry Curve 8530 Trackpad Replacement: step 5, image 3 of 3
      • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
      • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
      Ask FixBot
    4. BlackBerry Curve 8530 Trackpad Replacement: step 6, image 1 of 2 BlackBerry Curve 8530 Trackpad Replacement: step 6, image 2 of 2
      • The keyboard should slide off of the phone now that the plastic siding has been removed.
      Ask FixBot
    1. BlackBerry Curve 8530 Trackpad Replacement, Screen: step 7, image 1 of 3 BlackBerry Curve 8530 Trackpad Replacement, Screen: step 7, image 2 of 3 BlackBerry Curve 8530 Trackpad Replacement, Screen: step 7, image 3 of 3
      • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
      • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
      • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
      Ask FixBot
    2. BlackBerry Curve 8530 Trackpad Replacement: step 8, image 1 of 3 BlackBerry Curve 8530 Trackpad Replacement: step 8, image 2 of 3 BlackBerry Curve 8530 Trackpad Replacement: step 8, image 3 of 3
      • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
      • Use pressure to unlatch the screen from the clips.
      • Now that these clips have been undone, the screen should lift up easily.
      Ask FixBot
    1. BlackBerry Curve 8530 Trackpad Replacement, Motherboard: step 9, image 1 of 2 BlackBerry Curve 8530 Trackpad Replacement, Motherboard: step 9, image 2 of 2
      • Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver.
      Ask FixBot
    2. BlackBerry Curve 8530 Trackpad Replacement: step 10, image 1 of 3 BlackBerry Curve 8530 Trackpad Replacement: step 10, image 2 of 3 BlackBerry Curve 8530 Trackpad Replacement: step 10, image 3 of 3
      • Now the motherboard will lift up out of the plastic backing of the phone.
      Ask FixBot
    1. BlackBerry Curve 8530 Trackpad Replacement, Trackpad: step 11, image 1 of 3 BlackBerry Curve 8530 Trackpad Replacement, Trackpad: step 11, image 2 of 3 BlackBerry Curve 8530 Trackpad Replacement, Trackpad: step 11, image 3 of 3
      • Flip over the motherboard.
      • There is another torx screw near the middle of the motherboard on the left side.
      • Using the T5 Torx Screwdriver, remove the screw and the metal casing.
      • Note: Distinguish this screw from the others for reassembly purposes.
      • Detach the clip holding the track pad in.
      Ask FixBot
    2. BlackBerry Curve 8530 Trackpad Replacement: step 12, image 1 of 1
      • Remove the trackpad from the motherboard.
      • Now you are ready to reassemble the phone
      Ask FixBot
Finish Line
6 other people completed this guide.
Chris
227 Reputation
1 Guide authored
Cal Poly, Team 15-13, Regan Spring 2011 Member of Cal Poly, Team 15-13, Regan Spring 2011
CPSU-REGAN-S11S15G13
3 Members
60 Guides authored
1 Guide Comment
No need to full disassemble the phone. Just remove the back and the battery and unscrew the T5 screw, presto 20 minutes saved.
willdickerson - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 15,929
