BlackBerry Curve 8530 Keypad Replacement
    1. BlackBerry Curve 8530 Keypad Replacement, Battery: step 1, image 1 of 2 BlackBerry Curve 8530 Keypad Replacement, Battery: step 1, image 2 of 2
      • Place the phone on a flat surface with the screen facing down.
      • Remove the plastic backplate by pulling up on the bottom of the cover.
      Ask FixBot
    2. BlackBerry Curve 8530 Keypad Replacement: step 2, image 1 of 1
      • Remove the battery by pulling up from the top of the battery.
      Ask FixBot
    1. BlackBerry Curve 8530 Keypad Replacement, Keypad: step 3, image 1 of 2 BlackBerry Curve 8530 Keypad Replacement, Keypad: step 3, image 2 of 2
      • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
      • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
      Ask FixBot
    2. BlackBerry Curve 8530 Keypad Replacement: step 4, image 1 of 2 BlackBerry Curve 8530 Keypad Replacement: step 4, image 2 of 2
      • Flip the phone over so the keyboard faces up.
      • Insert a plastic spudger into the screen where speaker resides.
      • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
      • Gently lift up plastic screen cover until screen cover separates from screen.
      • Continue until screen cover is completely removed.
      Ask FixBot
    3. BlackBerry Curve 8530 Keypad Replacement: step 5, image 1 of 3 BlackBerry Curve 8530 Keypad Replacement: step 5, image 2 of 3 BlackBerry Curve 8530 Keypad Replacement: step 5, image 3 of 3
      • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
      • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
      Ask FixBot
    4. BlackBerry Curve 8530 Keypad Replacement: step 6, image 1 of 2 BlackBerry Curve 8530 Keypad Replacement: step 6, image 2 of 2
      • The keyboard should slide off of the phone now that the plastic siding has been removed.
      Ask FixBot
To reassemble the device, follow the instructions in reverse order.
4 other people completed this guide.
Cory Davis
503 Reputation
3 Guides authored
Cal Poly, Team 15-13, Regan Spring 2011 Member of Cal Poly, Team 15-13, Regan Spring 2011
CPSU-REGAN-S11S15G13
3 Members
60 Guides authored
1 Guide Comment
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 6,858
