BlackBerry Curve 8520 LCD Screen Replacement
    1. BlackBerry Curve 8520 LCD Screen Replacement, Back Panel: step 1, image 1 of 2 BlackBerry Curve 8520 LCD Screen Replacement, Back Panel: step 1, image 2 of 2
      • Insert a plastic opening tool into the small notch on the rear cover of the phone.
      • Pry the rear cover up from the phone.
      Ask FixBot
    1. BlackBerry Curve 8520 LCD Screen Replacement, Battery: step 2, image 1 of 2 BlackBerry Curve 8520 LCD Screen Replacement, Battery: step 2, image 2 of 2
      • Locate the slit between the top of the battery and the casing.
      • Gently apply pressure on the top of the battery to trigger the spring release.
      Ask FixBot
    1. BlackBerry Curve 8520 LCD Screen Replacement, Keyboard Cover: step 3, image 1 of 2 BlackBerry Curve 8520 LCD Screen Replacement, Keyboard Cover: step 3, image 2 of 2
      • Remove the two Torx T6 screws to the left and right of the battery.
      Ask FixBot
    2. BlackBerry Curve 8520 LCD Screen Replacement: step 4, image 1 of 2 BlackBerry Curve 8520 LCD Screen Replacement: step 4, image 2 of 2
      • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
      • Starting from one side, use a plastic opening tool to pry up the screen cover.
      • Work carefully to avoid bending the screen cover.
      • Once one side is loose, gently peel up the entire cover.
      Ask FixBot
    3. BlackBerry Curve 8520 LCD Screen Replacement: step 5, image 1 of 3 BlackBerry Curve 8520 LCD Screen Replacement: step 5, image 2 of 3 BlackBerry Curve 8520 LCD Screen Replacement: step 5, image 3 of 3
      • Insert the plastic opening tool in the seam along the side of the device.
      • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
      • Carefully remove the faceplate.
      Ask FixBot
    4. BlackBerry Curve 8520 LCD Screen Replacement: step 6, image 1 of 3 BlackBerry Curve 8520 LCD Screen Replacement: step 6, image 2 of 3 BlackBerry Curve 8520 LCD Screen Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Remove four T6 Torx screws from the front of the phone.
      • Using tweezers, remove the keyboard buttons from the phone.
      Ask FixBot
    1. BlackBerry Curve 8520 LCD Screen Replacement, Motherboard: step 7, image 1 of 2 BlackBerry Curve 8520 LCD Screen Replacement, Motherboard: step 7, image 2 of 2
      • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
      • Remove the four T6 Torx screws from the corners of the keyboard.
      Ask FixBot
    2. BlackBerry Curve 8520 LCD Screen Replacement: step 8, image 1 of 2 BlackBerry Curve 8520 LCD Screen Replacement: step 8, image 2 of 2
      • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
      Ask FixBot
12 other people completed this guide.
Matt
1,770 Reputation
5 Guides authored
Cal Poly, Team 9-62, Walters Spring 2011 Member of Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 36,486
