BlackBerry Curve 8520 Battery Replacement
    1. BlackBerry Curve 8520 Battery Replacement, Back Panel: step 1, image 1 of 2 BlackBerry Curve 8520 Battery Replacement, Back Panel: step 1, image 2 of 2
      • Insert a plastic opening tool into the small notch on the rear cover of the phone.
      • Pry the rear cover up from the phone.
      Ask FixBot
    1. BlackBerry Curve 8520 Battery Replacement, Battery: step 2, image 1 of 2 BlackBerry Curve 8520 Battery Replacement, Battery: step 2, image 2 of 2
      • Locate the slit between the top of the battery and the casing.
      • Gently apply pressure on the top of the battery to trigger the spring release.
      Ask FixBot
9 other people completed this guide.
Matt
1,770 Reputation
5 Guides authored
Cal Poly, Team 9-62, Walters Spring 2011 Member of Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Members
60 Guides authored
1 Guide Comment
very clear instructions
mirandaseagrave - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 89
All Time: 14,598
