BlackBerry Curve 8310 Trackball Replacement
  1. BlackBerry Curve 8310 Trackball Replacement, Battery: step 1, image 1 of 1
    • Press down on the battery release button and slide the back cover up with your thumb.
    Ask FixBot
  2. BlackBerry Curve 8310 Trackball Replacement: step 2, image 1 of 1
    • Pry from the top of the battery to pull it out.
    Ask FixBot
  3. BlackBerry Curve 8310 Trackball Replacement, Lens: step 3, image 1 of 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
    Ask FixBot
  4. BlackBerry Curve 8310 Trackball Replacement: step 4, image 1 of 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
    Ask FixBot
  5. BlackBerry Curve 8310 Trackball Replacement: step 5, image 1 of 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
    Ask FixBot
  6. BlackBerry Curve 8310 Trackball Replacement: step 6, image 1 of 3 BlackBerry Curve 8310 Trackball Replacement: step 6, image 2 of 3 BlackBerry Curve 8310 Trackball Replacement: step 6, image 3 of 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
    Ask FixBot
  7. BlackBerry Curve 8310 Trackball Replacement, Keyboard: step 7, image 1 of 1
    • Remove the keyboard.
    Ask FixBot
  8. BlackBerry Curve 8310 Trackball Replacement, Trackball: step 8, image 1 of 1
    • Use a spudger to pry off the plastic ring surrounding the trackball.
    Ask FixBot
  9. BlackBerry Curve 8310 Trackball Replacement: step 9, image 1 of 2 BlackBerry Curve 8310 Trackball Replacement: step 9, image 2 of 2
    • Remove the trackball from the phone.
    Ask FixBot
Sean Willis
229 Reputation
5 Guides authored
Cal Poly, Team 10-32, Amido Winter 2012 Member of Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 39
All Time: 4,133
