BlackBerry Bold 9700 LCD Display Replacement
  1. BlackBerry Bold 9700 LCD Display Replacement, Motherboard Housing: step 1, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement, Motherboard Housing: step 1, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement, Motherboard Housing: step 1, image 3 of 3
    • Remove the battery by prying the bottom of the battery upward.
    • Once the battery is angled up, pull it away from the top of the device.
    • Be sure to remove all power sources before working on electronic devices to avoid harming yourself or the device.
    Ask FixBot
  2. BlackBerry Bold 9700 LCD Display Replacement: step 2, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 2, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 2, image 3 of 3
    • Slide the SIM card from underneath the holding bracket upward toward the battery connector pins.
    • You must remove the SIM card before you can fully disassemble the device. Failure to do so may cause damage to components later on in this process.
    Ask FixBot
  3. BlackBerry Bold 9700 LCD Display Replacement: step 3, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 3, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 3, image 3 of 3
    • Pry off the AT&T logo panel with the plastic opening tool.
    • You will hear a snapping sound as the plastic tabs pop out.
    Ask FixBot
  4. BlackBerry Bold 9700 LCD Display Replacement: step 4, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 4, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 4, image 3 of 3
    • Use your T5 Torx screwdriver to remove the two black 5.57mm Torx head screws underneath the keyboard.
    Ask FixBot
  5. BlackBerry Bold 9700 LCD Display Replacement: step 5, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 5, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 5, image 3 of 3
    • Use the plastic opening tool to remove the frame of your device.
    • You will hear a snapping sound as the tabs pop out.
    • Once the case is loosened from the device, slide the case away from the top of the phone.
    Ask FixBot
  6. BlackBerry Bold 9700 LCD Display Replacement: step 6, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 6, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 6, image 3 of 3
    • Gently lift the bottom of the keyboard upward.
    • Pull the keyboard away from the bottom of the LCD display and lift upward.
    Ask FixBot
  7. BlackBerry Bold 9700 LCD Display Replacement: step 7, image 1 of 2 BlackBerry Bold 9700 LCD Display Replacement: step 7, image 2 of 2
    • Remove the two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
    Ask FixBot
  8. BlackBerry Bold 9700 LCD Display Replacement: step 8, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 8, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 8, image 3 of 3
    • Gently pry up the ribbon connector at the top of the phone with a plastic opening tool.
    • Ribbon connectors are fragile. Too much force in the wrong place will damage the ribbon and may force you to replace an entire assembly.
    Ask FixBot
  9. BlackBerry Bold 9700 LCD Display Replacement: step 9, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 9, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 9, image 3 of 3
    • Remove the top two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
    • You should now have two 5.57mm black torx head screws and four 4.13mm steel Torx head screws off to the side. Do not lose them.
    • Lift the clear plastic cover directly upward.
    Ask FixBot
  10. BlackBerry Bold 9700 LCD Display Replacement: step 10, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 10, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 10, image 3 of 3
    • Grip the motherboard by the screen
    • Lift the board away from the base of the housing and vertically up.
    Ask FixBot
  11. BlackBerry Bold 9700 LCD Display Replacement, LCD Display: step 11, image 1 of 2 BlackBerry Bold 9700 LCD Display Replacement, LCD Display: step 11, image 2 of 2
    • Flip the motherboard over so that the LCD display is flush with the surface of your work space.
    • Use a plastic opening tool to gently pry up the ribbon connector located on the left hand side of the motherboard.
    • Be gentle. Ribbon connectors are very fragile.
    Ask FixBot
  12. BlackBerry Bold 9700 LCD Display Replacement: step 12, image 1 of 2 BlackBerry Bold 9700 LCD Display Replacement: step 12, image 2 of 2
    • Use a plastic opening tool to gently pry back the two golden metal brackets at the top of the display.
    Ask FixBot
  13. BlackBerry Bold 9700 LCD Display Replacement: step 13, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 13, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 13, image 3 of 3
    • Use a plastic opening tool to pry the LCD display off the board.
    • The screen is held onto the board by two strong adhesive pads. You will need to pry vigorously. Do not be afraid of breaking the board. The screen will come off well before the board snaps.
    • Removing the trackpad prior to this repair is optional. If you wish to do so, follow this guide for removal instructions.
    Ask FixBot
  14. BlackBerry Bold 9700 LCD Display Replacement: step 14, image 1 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 14, image 2 of 3 BlackBerry Bold 9700 LCD Display Replacement: step 14, image 3 of 3
    • Insert the bottom prongs of the new LCD display into the golden slots above the trackpad resting panel.
    • Firmly press the new display into place.
    Ask FixBot
  15. BlackBerry Bold 9700 LCD Display Replacement: step 15, image 1 of 2 BlackBerry Bold 9700 LCD Display Replacement: step 15, image 2 of 2
    • Use a plastic opening tool to bend the golden brackets back into place
    • Press the ribbon connector into place.
    Ask FixBot
8 other people completed this guide.
Patrick
703 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 45
All Time: 6,525
