BlackBerry Bold 9700 Keyboard Replacement
    1. BlackBerry Bold 9700 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Remove the back panel by sliding it downward and lifting it away from the phone.
      Ask FixBot
    2. BlackBerry Bold 9700 Keyboard Replacement: step 2, image 1 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 2, image 2 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 2, image 3 of 3
      • Remove the battery by lifting the bottom edge of the battery from the bottom of the phone and up from the case.
      • (Warning: Power-off the device before removing the battery.)
      Ask FixBot
    3. BlackBerry Bold 9700 Keyboard Replacement: step 3, image 1 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 3, image 2 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 3, image 3 of 3
      • Remove the SIM card by pushing the card vertically through the bracket towards the top of the device.
      • The SIM card MUST be removed to disassemble the device.
      Ask FixBot
    4. BlackBerry Bold 9700 Keyboard Replacement: step 4, image 1 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 4, image 2 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to gently pry the bottom panel with the AT&T logo away from the phone.
      • Note: You will hear a snapping sound.
      Ask FixBot
    5. BlackBerry Bold 9700 Keyboard Replacement: step 5, image 1 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 5, image 2 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 5, image 3 of 3
      • Remove the front panel 5.57mm Torx head screws x2 with the T5 Torx screwdriver.
      Ask FixBot
    6. BlackBerry Bold 9700 Keyboard Replacement: step 6, image 1 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 6, image 2 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 6, image 3 of 3
      • Use the plastic opening tool to remove the frame.
      • This will take a bit of effort. You will hear a snapping sound.
      Ask FixBot
    7. BlackBerry Bold 9700 Keyboard Replacement: step 7, image 1 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 7, image 2 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 7, image 3 of 3
      • Gently lift the bottom of the keyboard up with your fingers and pull it toward the bottom of the phone.
      Ask FixBot
    8. BlackBerry Bold 9700 Keyboard Replacement: step 8, image 1 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 8, image 2 of 3 BlackBerry Bold 9700 Keyboard Replacement: step 8, image 3 of 3
      • Align the new keyboard to the bottom of the screen with the track pad slot angled downward.
      • Once the keyboard is flush with the screen, push the keyboard into place.
      Ask FixBot
To reassemble your device, follow these steps in reverse.
Danny
365 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 29
All Time: 1,819
