BlackBerry 8820 Motherboard Replacement
  1. BlackBerry 8820 Motherboard Replacement, Outer Casing: step 1, image 1 of 1
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
    Ask FixBot
  2. BlackBerry 8820 Motherboard Replacement: step 2, image 1 of 2 BlackBerry 8820 Motherboard Replacement: step 2, image 2 of 2
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
    Ask FixBot
  3. BlackBerry 8820 Motherboard Replacement: step 3, image 1 of 2 BlackBerry 8820 Motherboard Replacement: step 3, image 2 of 2
    • Carefully remove the two plastic side bars using a nylon spudger.
    Ask FixBot
  4. BlackBerry 8820 Motherboard Replacement: step 4, image 1 of 1
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
    Ask FixBot
  5. BlackBerry 8820 Motherboard Replacement: step 5, image 1 of 1
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
    Ask FixBot
  6. BlackBerry 8820 Motherboard Replacement, Motherboard: step 6, image 1 of 2 BlackBerry 8820 Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the bottom casing clip, which will easily unsnap when pulled.
    Ask FixBot
  7. BlackBerry 8820 Motherboard Replacement: step 7, image 1 of 2 BlackBerry 8820 Motherboard Replacement: step 7, image 2 of 2
    • Unhook both sides of the white wire from the motherboard using the plastic opening tool from before.
    Ask FixBot
  8. BlackBerry 8820 Motherboard Replacement: step 8, image 1 of 2 BlackBerry 8820 Motherboard Replacement: step 8, image 2 of 2
    • Locate the gloss SATA cable strap connecting LCD screen at the top of the phone.
    • Detach this cable by levering under the connector with a prying tool.
    • Handle with care when removing the ribbon cable handle, it is prone to breaking.
    Ask FixBot
  9. BlackBerry 8820 Motherboard Replacement: step 9, image 1 of 2 BlackBerry 8820 Motherboard Replacement: step 9, image 2 of 2
    • WARNING: Be sure to have disconnected the SATA cable strap before attempting.
    • Using the prying tool, lever the old screen up as shown.
    Ask FixBot
  10. BlackBerry 8820 Motherboard Replacement: step 10, image 1 of 3 BlackBerry 8820 Motherboard Replacement: step 10, image 2 of 3 BlackBerry 8820 Motherboard Replacement: step 10, image 3 of 3
    • There will be two small clips on each side of the motherboard. Unhook each clip one at a time using the plastic opening tool.
    • Once all four clips are unhooked you should be able to pull the motherboard from the casing with your hands.
    • After removing the old motherboard, you can now replace it with a new one.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. After replacing your BlackBerry's motherboard with a new one, recycle the old motherboard at an [[E-Waste#:~:text=Those%20dead%20parts%20should%20go,be%20put%20in%20the%20trash.|electronics recycler|new_window=true]].
3 other people completed this guide.
ryan
44 Reputation
5 Guides authored
Cal Poly, Team 13-64, Johann Spring 2013 Member of Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 1,395
