Up to 20% off select tools
BlackBerry 8820 Keyboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
76
All Time:
1,333
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the keyboard of the BlackBerry 8820. In order to do so, you must have a 1/16" diameter torx screwdriver and a plastic opening tool.
    1. BlackBerry 8820 Keyboard Replacement, Outer Casing: step 1, image 1 of 1
      • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
      Ask FixBot
    2. BlackBerry 8820 Keyboard Replacement: step 2, image 1 of 2 BlackBerry 8820 Keyboard Replacement: step 2, image 2 of 2
      • Remove the battery by prying under it with your finger or a plastic opening tool.
      • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
      Ask FixBot
    3. BlackBerry 8820 Keyboard Replacement: step 3, image 1 of 2 BlackBerry 8820 Keyboard Replacement: step 3, image 2 of 2
      • Carefully remove the two plastic side bars using a nylon spudger.
      Ask FixBot
    4. BlackBerry 8820 Keyboard Replacement: step 4, image 1 of 1
      • Carefully pry the back casing off with a nylon spudger.
      • There are two small clamps on each edge that need to be unhooked before the casing can come off.
      Ask FixBot
    5. BlackBerry 8820 Keyboard Replacement: step 5, image 1 of 1
      • Pry off the front casing.
      • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
      Ask FixBot
    1. BlackBerry 8820 Keyboard Replacement, Keyboard: step 6, image 1 of 1
      • Slide the keyboard downwards, as shown.
      • The keyboard will detach from the casing with a small amount of pressure.
      Ask FixBot
    2. BlackBerry 8820 Keyboard Replacement: step 7, image 1 of 2 BlackBerry 8820 Keyboard Replacement: step 7, image 2 of 2
      • Slide the new keyboard into the casing. If done correctly, it should click into place and stay secure.
      Ask FixBot
3 other people completed this guide.
Author
with
ryan
44 Reputation
5 Guides authored
Cal Poly, Team 13-64, Johann Spring 2013 Member of Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 76
All Time: 1,333
