Up to 20% off select tools
BlackBerry 8703e Case Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
3
Past 30 Days:
17
All Time:
5,360
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This repair guide shows how to disassemble the case on the BlackBerry 8703e to access the keyboard, logic board, and screen.
    1. BlackBerry 8703e Case Replacement, Battery: step 1, image 1 of 2 BlackBerry 8703e Case Replacement, Battery: step 1, image 2 of 2
      • Position your phone like the first image so that the highlighted button is on your left.
      • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
      • Remove the cover completely and set it aside.
      Ask FixBot
    2. BlackBerry 8703e Case Replacement: step 2, image 1 of 1
      • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
      • Locate the notch on the top right of the battery compartment.
      • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
      • Set the battery aside and out of the way.
      Ask FixBot
    1. BlackBerry 8703e Case Replacement, Case: step 3, image 1 of 2 BlackBerry 8703e Case Replacement, Case: step 3, image 2 of 2
      • Make sure the back of the phone is facing upwards like the image on the left.
      • Remove all three screws highlighted in the image by turning them counter-clockwise using the T6 Torx Screwdriver.
      Ask FixBot
    2. BlackBerry 8703e Case Replacement: step 4, image 1 of 2 BlackBerry 8703e Case Replacement: step 4, image 2 of 2
      • Locate the notch in the back of the phone.
      • Use your thumb to push up on the notch, separating the back half of the phone from the keyboard and screen in the front.
      • Slide the opening tool in between the two halves of the phone.
      • Continually apply upward pressure with the opening tool to pop the back casing off of the main body.
      • Set the back casing aside and out of the way.
      • You should now have five parts: The battery cover, the battery, the screws, the back casing, and the main body of the phone.
      Ask FixBot
    3. BlackBerry 8703e Case Replacement: step 5, image 1 of 1
      • Do not separate the front casing from the rest of the phone during this step. Keep the phone face-down on a flat surface.
      • Remove these four screws by turning them counter-clockwise with the T6 Torx Screwdriver.
      Ask FixBot
    4. BlackBerry 8703e Case Replacement: step 6, image 1 of 3 BlackBerry 8703e Case Replacement: step 6, image 2 of 3 BlackBerry 8703e Case Replacement: step 6, image 3 of 3
      • Hold the phone so the screen faces downward like in the first image, and remove the front casing.
      • Remove the two keyboard components from the front casing, then set them aside.
      • If the components or a black port protector fell out while removing the front case, then still set them aside. Take note that the two keyboard components may remain stuck together.
      Ask FixBot
2 other people completed this guide.
Author
with
Johnathon Gorski
40 Reputation
4 Guides authored
Cal Poly, Team 11-3, Forte Winter 2010 Member of Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 17
All Time: 5,360
