BlackBerry 8703e Battery Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
45
All Time:
3,896
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This repair guide shows how to remove the battery on the BlackBerry 8703e.
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
    1. BlackBerry 8703e Battery Replacement, Battery: step 1, image 1 of 2 BlackBerry 8703e Battery Replacement, Battery: step 1, image 2 of 2
      • Position your phone like the first image so that the highlighted button is on your left.
      • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
      • Remove the cover completely and set it aside.
      Ask FixBot
    2. BlackBerry 8703e Battery Replacement: step 2, image 1 of 1
      • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
      • Locate the notch on the top right of the battery compartment.
      • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
      • Set the battery aside and out of the way.
      Ask FixBot
Johnathon Gorski
40 Reputation
4 Guides authored
Cal Poly, Team 11-3, Forte Winter 2010 Member of Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 45
All Time: 3,896
