BlackBerry 7510 Keypad Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
40
All Time:
2,836
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This is a guide showing how to repair your keypad for the RIM blackberry 7510.
Tools
    1. BlackBerry 7510 Keypad Replacement, Back Face of Phone: step 1, image 1 of 1
      • Remove the battery cover and battery before continuing.
      • Remove the six T6 Torx screws on the back of the phone.
      • Make sure to keep the screws somewhere that they will not get lost.
      Ask FixBot
    2. BlackBerry 7510 Keypad Replacement: step 2, image 1 of 1
      • Using your finger nail or a spudger, carefully pry up the back cover.
      • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
      Ask FixBot
    3. BlackBerry 7510 Keypad Replacement: step 3, image 1 of 1
      • Lift off the back cover.
      Ask FixBot
    4. BlackBerry 7510 Keypad Replacement: step 4, image 1 of 1
      • Remove the two T6 screws.
      Ask FixBot
    5. BlackBerry 7510 Keypad Replacement: step 5, image 1 of 2 BlackBerry 7510 Keypad Replacement: step 5, image 2 of 2
      • Remove the daughterboard.
      • Remove the exposed vibration motor.
      Ask FixBot
    1. BlackBerry 7510 Keypad Replacement, Keypad: step 6, image 1 of 3 BlackBerry 7510 Keypad Replacement, Keypad: step 6, image 2 of 3 BlackBerry 7510 Keypad Replacement, Keypad: step 6, image 3 of 3
      • Unscrew metal plate.
      • Pry off front cover.
      • Lift off front cover to expose LCD screen.
      Ask FixBot
    2. BlackBerry 7510 Keypad Replacement: step 7, image 1 of 1
      • Remove keypad from front cover and replace or fix existing pad.
      Ask FixBot
Neil Johnson
12 Reputation
6 Guides authored
Cal Poly, Team 14-44, Regan Winter 2010 Member of Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 40
All Time: 2,836
