Up to 20% off select tools
BlackBerry 7290 SIM Card Replacement
Views: 6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
33
All Time:
6,039
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will show you step-by-step instructions on how to remove the SIM card from your RIM BlackBerry 7290.
    1. BlackBerry 7290 SIM Card Replacement, Battery: step 1, image 1 of 3 BlackBerry 7290 SIM Card Replacement, Battery: step 1, image 2 of 3 BlackBerry 7290 SIM Card Replacement, Battery: step 1, image 3 of 3
      • Apply pressure to the lock button on the back of the device.
      • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
      Ask FixBot
    2. BlackBerry 7290 SIM Card Replacement: step 2, image 1 of 3 BlackBerry 7290 SIM Card Replacement: step 2, image 2 of 3 BlackBerry 7290 SIM Card Replacement: step 2, image 3 of 3
      • Locate groove along the right side of the battery compartment.
      • Remove battery by prying between the battery and the groove.
      Ask FixBot
    1. BlackBerry 7290 SIM Card Replacement, SIM Card: step 3, image 1 of 1
      • Slide the SIM card holder to the left to unlock the SIM card.
      Ask FixBot
    2. BlackBerry 7290 SIM Card Replacement: step 4, image 1 of 2 BlackBerry 7290 SIM Card Replacement: step 4, image 2 of 2
      • Lift the SIM card holder up.
      • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
      Ask FixBot
Author
with
kmathew
6 Reputation
5 Guides authored
Cal Poly, Team 19-6, Maness Fall 2009 Member of Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Members
84 Guides authored
1 Guide Comment
What is the SIM card format?
elen m - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 6,039
