BlackBerry 7290 Motherboard Replacement
  1. BlackBerry 7290 Motherboard Replacement, Battery: step 1, image 1 of 3 BlackBerry 7290 Motherboard Replacement, Battery: step 1, image 2 of 3 BlackBerry 7290 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
    Ask FixBot
  2. BlackBerry 7290 Motherboard Replacement: step 2, image 1 of 3 BlackBerry 7290 Motherboard Replacement: step 2, image 2 of 3 BlackBerry 7290 Motherboard Replacement: step 2, image 3 of 3
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
    Ask FixBot
  3. BlackBerry 7290 Motherboard Replacement, SIM Card: step 3, image 1 of 1
    • Slide the SIM card holder to the left to unlock the SIM card.
    Ask FixBot
  4. BlackBerry 7290 Motherboard Replacement: step 4, image 1 of 2 BlackBerry 7290 Motherboard Replacement: step 4, image 2 of 2
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
    Ask FixBot
  5. BlackBerry 7290 Motherboard Replacement, Side Button: step 5, image 1 of 1
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
    Ask FixBot
  6. BlackBerry 7290 Motherboard Replacement: step 6, image 1 of 2 BlackBerry 7290 Motherboard Replacement: step 6, image 2 of 2
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
    Ask FixBot
  7. BlackBerry 7290 Motherboard Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
    Ask FixBot
  8. BlackBerry 7290 Motherboard Replacement: step 8, image 1 of 3 BlackBerry 7290 Motherboard Replacement: step 8, image 2 of 3 BlackBerry 7290 Motherboard Replacement: step 8, image 3 of 3
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
    Ask FixBot
  9. BlackBerry 7290 Motherboard Replacement: step 9, image 1 of 2 BlackBerry 7290 Motherboard Replacement: step 9, image 2 of 2
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
    Ask FixBot
  10. BlackBerry 7290 Motherboard Replacement, Keypad: step 10, image 1 of 1
    • To remove the phone's internals, start by loosening one side by pulling gently.
    Ask FixBot
  11. BlackBerry 7290 Motherboard Replacement: step 11, image 1 of 1
    • With one side loosened, simply lift the phone internals to separate from the front casing.
    Ask FixBot
  12. BlackBerry 7290 Motherboard Replacement: step 12, image 1 of 1
    • Turn the internals over to reveal the LCD display.
    Ask FixBot
  13. BlackBerry 7290 Motherboard Replacement: step 13, image 1 of 2 BlackBerry 7290 Motherboard Replacement: step 13, image 2 of 2
    • Peel off the rubber keypad buttons from the face plate.
    Ask FixBot
  14. BlackBerry 7290 Motherboard Replacement, LCD: step 14, image 1 of 1
    • Locate a hook on the right side of the internals below the volume wheel.
    • Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
    Ask FixBot
  15. BlackBerry 7290 Motherboard Replacement: step 15, image 1 of 2 BlackBerry 7290 Motherboard Replacement: step 15, image 2 of 2
    • With the clip unhooked, gently separate the display from the phone internals by pulling.
    Ask FixBot
  16. BlackBerry 7290 Motherboard Replacement, Logic Board: step 16, image 1 of 1
    • On the front side of the internals, locate the the three screws that are highlighted in red.
    • Carefully remove screws from the internals, using a T6 torx screwdriver
    • The screw is .2 inches in length.
    Ask FixBot
  17. BlackBerry 7290 Motherboard Replacement: step 17, image 1 of 2 BlackBerry 7290 Motherboard Replacement: step 17, image 2 of 2
    • Separate the logic board mounting plate from the logic board by lifting with minimal force.
    Ask FixBot
2 other people completed this guide.
kmathew
3 Reputation
5 Guides authored
Cal Poly, Team 19-6, Maness Fall 2009 Member of Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Members
15 Guides authored
2 Guide Comments
hi wonder if you can help or give me advice on my device. its not turning on looks like it turns on with the hour glass turning but nothing happens
douwmg - Reply Share
my device doesn't want to switch on its just the hour glass on the screen that turns on the screen but its not turning on?
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 56
All Time: 5,538
