BlackBerry 7290 LCD Replacement
    1. BlackBerry 7290 LCD Replacement, Battery: step 1, image 1 of 3 BlackBerry 7290 LCD Replacement, Battery: step 1, image 2 of 3 BlackBerry 7290 LCD Replacement, Battery: step 1, image 3 of 3
      • Apply pressure to the lock button on the back of the device.
      • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
      Ask FixBot
    2. BlackBerry 7290 LCD Replacement: step 2, image 1 of 3 BlackBerry 7290 LCD Replacement: step 2, image 2 of 3 BlackBerry 7290 LCD Replacement: step 2, image 3 of 3
      • Locate groove along the right side of the battery compartment.
      • Remove battery by prying between the battery and the groove.
      Ask FixBot
    1. BlackBerry 7290 LCD Replacement, SIM Card: step 3, image 1 of 1
      • Slide the SIM card holder to the left to unlock the SIM card.
      Ask FixBot
    2. BlackBerry 7290 LCD Replacement: step 4, image 1 of 2 BlackBerry 7290 LCD Replacement: step 4, image 2 of 2
      • Lift the SIM card holder up.
      • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
      Ask FixBot
    1. BlackBerry 7290 LCD Replacement, Side Button: step 5, image 1 of 1
      • Locate the four screws along the perimeter of the back casing.
      • Remove the four top screws using a T-6 torx screwdriver.
      • The top four screws are .413 inches.
      Ask FixBot
    2. BlackBerry 7290 LCD Replacement: step 6, image 1 of 2 BlackBerry 7290 LCD Replacement: step 6, image 2 of 2
      • Locate two screws within the lower edge of the inner compartment.
      • Remove the two bottom screws using a T-6 torx screwdriver.
      • The bottom two screws are .2 inches in length.
      • The second picture displays the device after the six screws have been removed.
      Ask FixBot
    3. BlackBerry 7290 LCD Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
      Ask FixBot
    4. BlackBerry 7290 LCD Replacement: step 8, image 1 of 3 BlackBerry 7290 LCD Replacement: step 8, image 2 of 3 BlackBerry 7290 LCD Replacement: step 8, image 3 of 3
      • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
      • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
      Ask FixBot
    5. BlackBerry 7290 LCD Replacement: step 9, image 1 of 2 BlackBerry 7290 LCD Replacement: step 9, image 2 of 2
      • Locate on the backside of the phone, a screw towards the top of the device.
      • Using a T-6 screwdriver, remove the screw.
      • After the screw has been removed, carefully lift the side button brace to reveal the side button.
      Ask FixBot
    1. BlackBerry 7290 LCD Replacement, Keypad: step 10, image 1 of 1
      • To remove the phone's internals, start by loosening one side by pulling gently.
      Ask FixBot
    2. BlackBerry 7290 LCD Replacement: step 11, image 1 of 1
      • With one side loosened, simply lift the phone internals to separate from the front casing.
      Ask FixBot
    3. BlackBerry 7290 LCD Replacement: step 12, image 1 of 1
      • Turn the internals over to reveal the LCD display.
      Ask FixBot
    4. BlackBerry 7290 LCD Replacement: step 13, image 1 of 2 BlackBerry 7290 LCD Replacement: step 13, image 2 of 2
      • Peel off the rubber keypad buttons from the face plate.
      Ask FixBot
    1. BlackBerry 7290 LCD Replacement, LCD: step 14, image 1 of 1
      • Locate a hook on the right side of the internals below the volume wheel.
      • Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
      Ask FixBot
    2. BlackBerry 7290 LCD Replacement: step 15, image 1 of 2 BlackBerry 7290 LCD Replacement: step 15, image 2 of 2
      • With the clip unhooked, gently separate the display from the phone internals by pulling.
      Ask FixBot
kmathew
3 Reputation
5 Guides authored
Cal Poly, Team 19-6, Maness Fall 2009 Member of Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 6,461
