Up to 20% off select tools
BlackBerry 7280 Inner Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
6
Past 30 Days:
19
All Time:
665
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The inner keyboard is the internal part of the device's keyboard. This part provides connections between the rubber keys and the device's motherboard. This guide demonstrates how to remove the inner keyboard after removing the outer case.
    1. BlackBerry 7280 Inner Keyboard Replacement, Battery: step 1, image 1 of 3 BlackBerry 7280 Inner Keyboard Replacement, Battery: step 1, image 2 of 3 BlackBerry 7280 Inner Keyboard Replacement, Battery: step 1, image 3 of 3
      • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
      • Slide the battery cover off the device.
      Ask FixBot
    2. BlackBerry 7280 Inner Keyboard Replacement: step 2, image 1 of 2 BlackBerry 7280 Inner Keyboard Replacement: step 2, image 2 of 2
      • Remove the lithium-ion battery from the back of the device using your index finger.
      Ask FixBot
    1. BlackBerry 7280 Inner Keyboard Replacement, SIM Card: step 3, image 1 of 3 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: step 3, image 2 of 3 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: step 3, image 3 of 3
      • Hold the device with both hands.
      • Lift the SIM card holder using your thumb and index finger.
      • Remove the SIM card from the device.
      Ask FixBot
    1. BlackBerry 7280 Inner Keyboard Replacement, Back Case: step 4, image 1 of 2 BlackBerry 7280 Inner Keyboard Replacement, Back Case: step 4, image 2 of 2
      • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
      • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
      Ask FixBot
    2. BlackBerry 7280 Inner Keyboard Replacement: step 5, image 1 of 2 BlackBerry 7280 Inner Keyboard Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to pry the back case away from the front case.
      Ask FixBot
    1. BlackBerry 7280 Inner Keyboard Replacement, Front Case: step 6, image 1 of 2 BlackBerry 7280 Inner Keyboard Replacement, Front Case: step 6, image 2 of 2
      • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
      Ask FixBot
    2. BlackBerry 7280 Inner Keyboard Replacement: step 7, image 1 of 2 BlackBerry 7280 Inner Keyboard Replacement: step 7, image 2 of 2
      • Remove the front plastic case from the metal bracket.
      Ask FixBot
    1. BlackBerry 7280 Inner Keyboard Replacement, Inner Keyboard: step 8, image 1 of 1
      • To remove the inner keyboard, simply peel it off of the logic board as shown.
      Ask FixBot
Author
with
Andrew Johnston
4 Reputation
2 Guides authored
Clemson, Team 12-2, Benson Spring 2013 Member of Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 19
All Time: 665
