Up to 20% off select tools
BlackBerry 7280 Back Case Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
23
All Time:
736
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The outer shell of the BlackBerry 7280 has two main parts, the back case and the front case. The back case is the first part that has to be removed, and allows access to more internal parts of the device.
    1. BlackBerry 7280 Back Case Replacement, Battery: step 1, image 1 of 3 BlackBerry 7280 Back Case Replacement, Battery: step 1, image 2 of 3 BlackBerry 7280 Back Case Replacement, Battery: step 1, image 3 of 3
      • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
      • Slide the battery cover off the device.
      Ask FixBot
    2. BlackBerry 7280 Back Case Replacement: step 2, image 1 of 2 BlackBerry 7280 Back Case Replacement: step 2, image 2 of 2
      • Remove the lithium-ion battery from the back of the device using your index finger.
      Ask FixBot
    1. BlackBerry 7280 Back Case Replacement, SIM Card: step 3, image 1 of 3 BlackBerry 7280 Back Case Replacement, SIM Card: step 3, image 2 of 3 BlackBerry 7280 Back Case Replacement, SIM Card: step 3, image 3 of 3
      • Hold the device with both hands.
      • Lift the SIM card holder using your thumb and index finger.
      • Remove the SIM card from the device.
      Ask FixBot
    1. BlackBerry 7280 Back Case Replacement, Back Case: step 4, image 1 of 2 BlackBerry 7280 Back Case Replacement, Back Case: step 4, image 2 of 2
      • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
      • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
      Ask FixBot
    2. BlackBerry 7280 Back Case Replacement: step 5, image 1 of 2 BlackBerry 7280 Back Case Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to pry the back case away from the front case.
      Ask FixBot
Author
with
Sarah Waddill
10 Reputation
5 Guides authored
Clemson, Team 12-2, Benson Spring 2013 Member of Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 736
