Up to 20% off select tools
BlackBerry 7100g Screen Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
88
All Time:
2,630
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows you how to replace the screen from your BlackBerry 7100g.
    1. BlackBerry 7100g Screen Replacement, Battery: step 1, image 1 of 1
      • Turn over your BalckBerry 7100g so that the back cover is facing up.
      • Locate the battery cover release button near the bottom of the back panel.
      Ask FixBot
    2. BlackBerry 7100g Screen Replacement: step 2, image 1 of 3 BlackBerry 7100g Screen Replacement: step 2, image 2 of 3 BlackBerry 7100g Screen Replacement: step 2, image 3 of 3
      • Push down on the release button with one thumb.
      • Slide the battery cover off with the other thumb.
      Ask FixBot
    3. BlackBerry 7100g Screen Replacement: step 3, image 1 of 1
      • Remove the battery from the battery housing by flipping up the top of the battery.
      Ask FixBot
    1. BlackBerry 7100g Screen Replacement, Housing: step 4, image 1 of 3 BlackBerry 7100g Screen Replacement, Housing: step 4, image 2 of 3 BlackBerry 7100g Screen Replacement, Housing: step 4, image 3 of 3
      • Locate the silver strip near the top of your BlackBerry.
      • Use a plastic opening tool to pry off the edge of the silver lining.
      • Slide the tool along the length of the silver strip to completely remove it.
      Ask FixBot
    2. BlackBerry 7100g Screen Replacement: step 5, image 1 of 2 BlackBerry 7100g Screen Replacement: step 5, image 2 of 2
      • Do not lose the screws. They are quite small and can easily be misplaced.
      • Locate and unscrew the four (4) screws using a T6 screwdriver.
      Ask FixBot
    3. BlackBerry 7100g Screen Replacement: step 6, image 1 of 3 BlackBerry 7100g Screen Replacement: step 6, image 2 of 3 BlackBerry 7100g Screen Replacement: step 6, image 3 of 3
      • The keypad cover may fall out of the housing when prying the housing apart.
      • Tightly pinch the top of the front and back halves of the housing.
      • Carefully pry the two halves of the housing apart.
      Ask FixBot
    4. BlackBerry 7100g Screen Replacement: step 7, image 1 of 1
      • You can now easily remove the "guts" of the phone from the housing.
      Ask FixBot
    1. BlackBerry 7100g Screen Replacement, Keypad: step 8, image 1 of 3 BlackBerry 7100g Screen Replacement, Keypad: step 8, image 2 of 3 BlackBerry 7100g Screen Replacement, Keypad: step 8, image 3 of 3
      • Turn the "guts" over so the speaker is facing up.
      • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
      • Separate the battery housing from the motherboard.
      Ask FixBot
    2. BlackBerry 7100g Screen Replacement: step 9, image 1 of 1
      • Pull the keypad off of the motherboard.
      • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
      Ask FixBot
    1. BlackBerry 7100g Screen Replacement, Screen: step 10, image 1 of 2 BlackBerry 7100g Screen Replacement, Screen: step 10, image 2 of 2
      • Locate the ribbon connector below the bottom of the screen.
      • Use a spudger to flip up the connector.
      Ask FixBot
    2. BlackBerry 7100g Screen Replacement: step 11, image 1 of 3 BlackBerry 7100g Screen Replacement: step 11, image 2 of 3 BlackBerry 7100g Screen Replacement: step 11, image 3 of 3
      • Locate the four (4) white tabs that attach the screen to the motherboard.
      • Carefully detach the tabs from the motherboard.
      • The screen can now be removed from the motherboard.
      Ask FixBot
Author
with
Adriel Salinas
42 Reputation
2 Guides authored
Cal Poly, Team 25-87, Amido Spring 2010 Member of Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Members
96 Guides authored
1 Guide Comment
just a heads up don't do this with a iPhone it does not work at All!
Jaxson HUTCHINSON - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 88
All Time: 2,630
