Black and Decker TR1278B Lever Catch-Spring Replacement
  1. Black and Decker TR1278B Lever Catch-Spring Replacement, Top Cover: step 1, image 1 of 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
    Ask FixBot
  2. Black and Decker TR1278B Lever Catch-Spring Replacement: step 2, image 1 of 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
    Ask FixBot
  3. Black and Decker TR1278B Lever Catch-Spring Replacement: step 3, image 1 of 1
    • Detach the bottom from the front cover using the plastic opening tool.
    Ask FixBot
  4. Black and Decker TR1278B Lever Catch-Spring Replacement: step 4, image 1 of 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
    Ask FixBot
  5. Black and Decker TR1278B Lever Catch-Spring Replacement: step 5, image 1 of 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
    Ask FixBot
  6. Black and Decker TR1278B Lever Catch-Spring Replacement, Lever Catch Spring: step 6, image 1 of 1
    • Lift the top cover up and remove it from the toaster.
    Ask FixBot
  7. Black and Decker TR1278B Lever Catch-Spring Replacement: step 7, image 1 of 1
    • Locate the springs.
    • There is a top spring and bottom spring.
    Ask FixBot
  8. Black and Decker TR1278B Lever Catch-Spring Replacement: step 8, image 1 of 2 Black and Decker TR1278B Lever Catch-Spring Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use needle nose tweezers to free one end of the spring.
    • Turn the spring until it is completely free.
    Ask FixBot
  9. Black and Decker TR1278B Lever Catch-Spring Replacement: step 9, image 1 of 1
    • Remove spring for replacement.
    • Repeat steps for bottom spring.
    Ask FixBot
2 other people completed this guide.
Brea-Monique
399 Reputation
3 Guides authored
USF Tampa, Team 8-1, Eyestone Spring 2017 Member of USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 Members
5 Guides authored
1 Guide Comment
Hi there, thanks for this guide. I have a little issue : one of the screws is quite unusual, probably because it’s not meant to be repaired by a poor peasant. It has a little pin in it and I can’t unscrew it with the tools I have. Any tips ?
ToasterMaster - Reply Share
Past 24 Hours: 6
Past 7 Days: 12
Past 30 Days: 58
All Time: 1,988
