Black and Decker Pivot MAX Power Switch Replacement
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: step 1, image 1 of 2 Black and Decker Pivot MAX Power Switch Replacement, Battery: step 1, image 2 of 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
    Ask FixBot
  2. Black and Decker Pivot MAX Power Switch Replacement: step 2, image 1 of 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
    Ask FixBot
  3. Black and Decker Pivot MAX Power Switch Replacement: step 3, image 1 of 1
    • Pull the battery cover up and then slide it away from the motor to remove.
    Ask FixBot
  4. Black and Decker Pivot MAX Power Switch Replacement: step 4, image 1 of 1
    • Remove the battery unit by pulling it out of the main body.
    Ask FixBot
  5. Black and Decker Pivot MAX Power Switch Replacement: step 5, image 1 of 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
    Ask FixBot
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: step 6, image 1 of 1
    • Remove the handle cover by removing the three PH1 20mm screws
    Ask FixBot
  7. Black and Decker Pivot MAX Power Switch Replacement: step 7, image 1 of 1
    • Pull out the pivot lock button.
    Ask FixBot
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: step 8, image 1 of 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: step 8, image 2 of 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: step 8, image 3 of 3
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
    Ask FixBot
  9. Black and Decker Pivot MAX Power Switch Replacement: step 9, image 1 of 2 Black and Decker Pivot MAX Power Switch Replacement: step 9, image 2 of 2
    Ask FixBot
1 Guide Comment
Where may I buy a power switch?
Joan Williamson - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 43
All Time: 1,408
