Black and Decker Pivot MAX Pivot Lock Button Replacement
  1. Black and Decker Pivot MAX Pivot Lock Button Replacement, Battery: step 1, image 1 of 2 Black and Decker Pivot MAX Pivot Lock Button Replacement, Battery: step 1, image 2 of 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
    Ask FixBot
  2. Black and Decker Pivot MAX Pivot Lock Button Replacement: step 2, image 1 of 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
    Ask FixBot
  3. Black and Decker Pivot MAX Pivot Lock Button Replacement: step 3, image 1 of 1
    • Pull the battery cover up and then slide it away from the motor to remove.
    Ask FixBot
  4. Black and Decker Pivot MAX Pivot Lock Button Replacement: step 4, image 1 of 1
    • Remove the battery unit by pulling it out of the main body.
    Ask FixBot
  5. Black and Decker Pivot MAX Pivot Lock Button Replacement: step 5, image 1 of 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
    Ask FixBot
  6. Black and Decker Pivot MAX Pivot Lock Button Replacement, Pivot Lock Button: step 6, image 1 of 1
    • Remove the handle cover by removing the three PH1 20mm screws
    Ask FixBot
  7. Black and Decker Pivot MAX Pivot Lock Button Replacement: step 7, image 1 of 1
    • Pull out the pivot lock button.
    Ask FixBot
Jesse Sipes
598 Reputation
2 Guides authored
IUPUI, Team S5-G6, Baechle Fall 2017 Member of IUPUI, Team S5-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G6
3 Members
9 Guides authored
4 Guide Comments
How does the fan blade come off
Darcy Lee - Reply Share
Darcy, there are a lot more steps for that. You have to pry off the grey ring around the motor housing, then unscrew the housing. Once you are able to remove the motor assembly from the rest of the vacuum, you flip it over and the fan blade is a flat disk mounted on the opposite side of the motor drive. Carefully pry it out. (A step by step with pics would help make a lot more sense of this.)
Brad Kik - Reply Share
The thermal fuse cannot get it from B&D.
I have a bad one the vacuum starts and stops. Where can I buy the fuse?
George Chryssanthou - Reply Share
@fixit_18 you cannot replace the fuse. This device is not intended to be repaired. This tutorial is useless as parts are not available. Anyone who has one of theses knows it and will likely have to fabricate their own replacement parts…… I need a battery and will be building one from scratch….
paddy - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 34
All Time: 3,937
