Black and Decker PS1800 Case Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Black and Decker PS1800 Case Replacement, Open the Outer Drill Case: step 1, image 1 of 2 Black and Decker PS1800 Case Replacement, Open the Outer Drill Case: step 1, image 2 of 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  2. Black and Decker PS1800 Case Replacement: step 2, image 1 of 1
    • Separate the outer drill case to expose the components and switch.
    Ask FixBot
Christian Aldrich
253 Reputation
2 Guides authored
IUPUI, Team 2-3, Baechle Fall 2016 Member of IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 384
