Black and Decker LI2000 Orange Casing Replacement
    1. Black and Decker LI2000 Orange Casing Replacement, Orange Casing: step 1, image 1 of 3 Black and Decker LI2000 Orange Casing Replacement, Orange Casing: step 1, image 2 of 3 Black and Decker LI2000 Orange Casing Replacement, Orange Casing: step 1, image 3 of 3
      • Remove the following five screws
      • Three 20 mm Phillips #1 screws
      • One 10 mm #000 Phillips screw
      • One 13 mm Phillips 31 screw
      • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
      Ask FixBot
    2. Black and Decker LI2000 Orange Casing Replacement: step 2, image 1 of 1
      • Remove the black sticker with recycling information.
      Ask FixBot
    3. Black and Decker LI2000 Orange Casing Replacement: step 3, image 1 of 1
      • Use your fingers or a plastic opening tool to pry the casing apart.
      Ask FixBot
    4. Black and Decker LI2000 Orange Casing Replacement: step 4, image 1 of 1
      • Remove the plastic slider by picking it up off the screwdriver.
      • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
      Ask FixBot
Katherine Simmons
753 Reputation
5 Guides authored
IUPUI, Team 1-3, Baechle Spring 2016 Member of IUPUI, Team 1-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G3
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 704
