Black and Decker JS660 Angle Lock Replacement
    1. Black and Decker JS660 Angle Lock Replacement, Base: step 1, image 1 of 2 Black and Decker JS660 Angle Lock Replacement, Base: step 1, image 2 of 2
      • Unscrew the eight screws to open up the jigsaw.
      Ask FixBot
    2. Black and Decker JS660 Angle Lock Replacement: step 2, image 1 of 1
      • Use a screwdriver to remove the first screws securing the base to the jigsaw.
      • Remove the second screw.
      • Remove the base of the jigsaw.
      Ask FixBot
    3. Black and Decker JS660 Angle Lock Replacement: step 3, image 1 of 2 Black and Decker JS660 Angle Lock Replacement: step 3, image 2 of 2
      • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
      • Assemble the base on a steady surface.
      Ask FixBot
    1. Black and Decker JS660 Angle Lock Replacement, Angle Lock: step 4, image 1 of 3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: step 4, image 2 of 3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: step 4, image 3 of 3
      • Remove the screw marked and the lever will slide out easily
      • The black screw must next be removed.
      • After removing the screw the lever will slide out of the jigsaw.
      Ask FixBot
Andrew Khouri
468 Reputation
4 Guides authored
USF Tampa, Team 6-2, Eyestone Spring 2016 Member of USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 22
All Time: 537
