Black and Decker JS660 Angle Knob Replacement
  1. Black and Decker JS660 Angle Knob Replacement, Base: step 1, image 1 of 2 Black and Decker JS660 Angle Knob Replacement, Base: step 1, image 2 of 2
    • Unscrew the eight screws to open up the jigsaw.
    Ask FixBot
  2. Black and Decker JS660 Angle Knob Replacement: step 2, image 1 of 1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
    Ask FixBot
  3. Black and Decker JS660 Angle Knob Replacement: step 3, image 1 of 2 Black and Decker JS660 Angle Knob Replacement: step 3, image 2 of 2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
    Ask FixBot
  4. Black and Decker JS660 Angle Knob Replacement, Angle Knob: step 4, image 1 of 3 Black and Decker JS660 Angle Knob Replacement, Angle Knob: step 4, image 2 of 3 Black and Decker JS660 Angle Knob Replacement, Angle Knob: step 4, image 3 of 3
    • As soon you disassemble the device, you can see the angle knob is not attached to any screws.
    • Remove the angle knob from the device.
    Ask FixBot
Andrew Khouri
468 Reputation
4 Guides authored
USF Tampa, Team 6-2, Eyestone Spring 2016 Member of USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 617
