Black and Decker CM0700BZ Power Button Replacement
  1. Black and Decker CM0700BZ Power Button Replacement, Power Button: step 1, image 1 of 2 Black and Decker CM0700BZ Power Button Replacement, Power Button: step 1, image 2 of 2
    • Ensure power cord is unplugged from the wall.
    • Remove the carafe holder from the bottom of the coffee machine.
    Ask FixBot
  2. Black and Decker CM0700BZ Power Button Replacement: step 2, image 1 of 3 Black and Decker CM0700BZ Power Button Replacement: step 2, image 2 of 3 Black and Decker CM0700BZ Power Button Replacement: step 2, image 3 of 3
    • Place coffee maker on its side, with the bottom facing you.
    • Remove the two 10 mm Phillips #1 screws.
    • Remove one 10 mm Tri-Point Y1 screw.
    Ask FixBot
  3. Black and Decker CM0700BZ Power Button Replacement: step 3, image 1 of 3 Black and Decker CM0700BZ Power Button Replacement: step 3, image 2 of 3 Black and Decker CM0700BZ Power Button Replacement: step 3, image 3 of 3
    • Slowly pry the bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid.
    Ask FixBot
  4. Black and Decker CM0700BZ Power Button Replacement: step 4, image 1 of 3 Black and Decker CM0700BZ Power Button Replacement: step 4, image 2 of 3 Black and Decker CM0700BZ Power Button Replacement: step 4, image 3 of 3
    • Using a screwdriver or spudger, firmly press on the middle of heat shrink and pull each electrical connection apart.
    • Gently push the power button out of the housing while pushing the tabs inwards.
    Ask FixBot
  5. Black and Decker CM0700BZ Power Button Replacement: step 5, image 1 of 3 Black and Decker CM0700BZ Power Button Replacement: step 5, image 2 of 3 Black and Decker CM0700BZ Power Button Replacement: step 5, image 3 of 3
    • Use a screwdriver or spudger to pry out the power button.
    Ask FixBot
3 other people completed this guide.
Ramez Gerges
136 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 124
All Time: 3,239
