Black and Decker BDEDMT Trigger Device Replacement
    1. Black and Decker BDEDMT Trigger Device Replacement, Detach Matrix Attachment: step 1, image 1 of 2 Black and Decker BDEDMT Trigger Device Replacement, Detach Matrix Attachment: step 1, image 2 of 2
      • Remember to disconnect the device from all external power sources.
      • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
      • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
      Ask FixBot
    2. Black and Decker BDEDMT Trigger Device Replacement, Remove Mounting Hardware: step 2, image 1 of 3 Black and Decker BDEDMT Trigger Device Replacement, Remove Mounting Hardware: step 2, image 2 of 3 Black and Decker BDEDMT Trigger Device Replacement, Remove Mounting Hardware: step 2, image 3 of 3
      • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
      • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
      Ask FixBot
    1. Black and Decker BDEDMT Trigger Device Replacement, Trigger Device: step 3, image 1 of 1
      • Grab a hold of the trigger module. Gently lift the module out of the armature.
      • Be gentle with the module to ensure that the reverse switch is unaffected.
      Ask FixBot
    2. Black and Decker BDEDMT Trigger Device Replacement: step 4, image 1 of 3 Black and Decker BDEDMT Trigger Device Replacement: step 4, image 2 of 3 Black and Decker BDEDMT Trigger Device Replacement: step 4, image 3 of 3
      • Simply roll the trigger module onto its back.
      • Located on on the bottom left of the module there will be a screw with the label 3.
      • Use your a JIS 0 screwdriver. After the screw is released, gently pull out the black wire.
      • The power cord is released from the trigger module.
      Ask FixBot
    3. Black and Decker BDEDMT Trigger Device Replacement: step 5, image 1 of 3 Black and Decker BDEDMT Trigger Device Replacement: step 5, image 2 of 3 Black and Decker BDEDMT Trigger Device Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Located on the bottom side there will be a labeled area with a number 2. Below the two there will be a short white wire.
      • Using your needle nose tweezers insert one of the ends into the release slot below the white wire.
      • Make sure aim the tweezers toward the wire.
      • Lift the end of the tweezers to release the wire.
      • Do not force the removal of the wire.
      Ask FixBot
    4. Black and Decker BDEDMT Trigger Device Replacement: step 6, image 1 of 3 Black and Decker BDEDMT Trigger Device Replacement: step 6, image 2 of 3 Black and Decker BDEDMT Trigger Device Replacement: step 6, image 3 of 3
      • Located on the top of the trigger module you will see four more wires entering the module. There will be two thin black wires, a thin white wire and a thin red wire.
      • The steps for the removal of these four wires is the same as seen in step number five.
      • Remember to reinsert the wires to their corresponding slots when reassembling.
      • The trigger module is now completely free from the rest of the device and can be replaced.
      Ask FixBot
cayla dahl
247 Reputation
2 Guides authored
UW Tacoma, Team 1-2, Rose Winter 2016 Member of UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Members
42 Guides authored
1 Guide Comment
Hello,
Can this switch be replace by another B&D switch ?
Thanks,
Mario
Mario Basque - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 65
All Time: 1,928
