Bissell Zing 2156A Rear Filter Replacement
  1. Bissell Zing 2156A Rear Filter Replacement, Rear Filter: step 1, image 1 of 1
    • While holding the top of the vacuum with one hand, use the other hand to push the clamp down that holds the rear filter in place.
    Ask FixBot
  2. Bissell Zing 2156A Rear Filter Replacement: step 2, image 1 of 1
    • Hold the grille with one hand.
    • With the other hand, grab ahold of the foam and separate it from the grille.
    Ask FixBot
  3. Bissell Zing 2156A Rear Filter Replacement: step 3, image 1 of 1
    • Remove any large piece of debris by hand from the grille.
    • The grille can be gently rinsed over a faucet. Be sure to dry the grill before reassembly.
    • Remove any large piece of debris by hand gently from the foam.
    • The foam should never touch water or any kind of liquid.
    • If any part of the rear filter becomes damaged or too filthy to clean, replace it.
    Ask FixBot
1 Guide Comment
This article was very helpful. I had no idea the vac had a rear filter.
Lesley Butterworth - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 438
