Bissell Zing 2156A Case Replacement
  1. Bissell Zing 2156A Case Replacement, Rear Wheel: step 1, image 1 of 1
    • Remove the dust tank, so the vacuum can lie upside down easily.
    • Press the grey button while pulling up.
    Ask FixBot
  2. Bissell Zing 2156A Case Replacement: step 2, image 1 of 1
    • Flip the vacuum upside down.
    Ask FixBot
  3. Bissell Zing 2156A Case Replacement: step 3, image 1 of 3 Bissell Zing 2156A Case Replacement: step 3, image 2 of 3 Bissell Zing 2156A Case Replacement: step 3, image 3 of 3
    • Place your hand inside between the wheel and vacuum and pry the wheel off.
    • Repeat with the other side.
    Ask FixBot
  4. Bissell Zing 2156A Case Replacement, Case: step 4, image 1 of 2 Bissell Zing 2156A Case Replacement, Case: step 4, image 2 of 2
    • Remove the two 18.1 mm screws using a Phillips #0 screwdriver.
    • Remove the four 18.1 mm screws under the wheels using a Phillips #0 screwdriver.
    • Don't try this until you have removed the wheels!
    Ask FixBot
  5. Bissell Zing 2156A Case Replacement: step 5, image 1 of 3 Bissell Zing 2156A Case Replacement: step 5, image 2 of 3 Bissell Zing 2156A Case Replacement: step 5, image 3 of 3
    • Use the spudger to loosen the top case from the bottom. Make sure to loosen it all around the bottom and lift up.
    Ask FixBot
Terrance
283 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 65
All Time: 1,230
