Up to 20% off select tools
Bissell SpotBot Pet Control Panel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
98
All Time:
1,233
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a guide on how to replace the spiral brushing system on a bissell spotbot pet. Use this if your spiral brushing system is not working properly.
    1. Bissell SpotBot Pet Control Panel Replacement, Control Panel: step 1, image 1 of 1
      • Start here.
      Ask FixBot
    2. Bissell SpotBot Pet Control Panel Replacement: step 2, image 1 of 1
      • Remove the container on the right side of the vacuum.
      Ask FixBot
    3. Bissell SpotBot Pet Control Panel Replacement: step 3, image 1 of 2 Bissell SpotBot Pet Control Panel Replacement: step 3, image 2 of 2
      • Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
      Ask FixBot
    4. Bissell SpotBot Pet Control Panel Replacement: step 4, image 1 of 1
      • Remove the left container of the vacuum.
      Ask FixBot
    5. Bissell SpotBot Pet Control Panel Replacement: step 5, image 1 of 1
      • Remove the four screws on the top of the device.
      Ask FixBot
    6. Bissell SpotBot Pet Control Panel Replacement: step 6, image 1 of 1
      • Lift the top of the device off once the screws are removed.
      Ask FixBot
    7. Bissell SpotBot Pet Control Panel Replacement: step 7, image 1 of 1
      • Unplug the ribbon cable from the motherboard.
      Ask FixBot
    8. Bissell SpotBot Pet Control Panel Replacement: step 8, image 1 of 1
      • Separate the top piece and flip it upside down.
      Ask FixBot
    9. Bissell SpotBot Pet Control Panel Replacement: step 9, image 1 of 2 Bissell SpotBot Pet Control Panel Replacement: step 9, image 2 of 2
      • Remove the screws holding the motherboard in place.
      Ask FixBot
    10. Bissell SpotBot Pet Control Panel Replacement: step 10, image 1 of 2 Bissell SpotBot Pet Control Panel Replacement: step 10, image 2 of 2
      • Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
      Ask FixBot
4 other people completed this guide.
Author
with
Anthony Bonvino
455 Reputation
2 Guides authored
Cal Poly, Team S7-G3, Banghart Fall 2017 Member of Cal Poly, Team S7-G3, Banghart Fall 2017
CPSU-BANGHART-F17S7G3
4 Members
24 Guides authored
1 Guide Comment
Where can I buy the part?
Sue Loberger - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 98
All Time: 1,233
