Bissell Spinwave Pet Battery Replacement
    1. Bissell Spinwave Pet Battery Replacement, Side Brush: step 1, image 1 of 2 Bissell Spinwave Pet Battery Replacement, Side Brush: step 1, image 2 of 2
      • Place the Bissell Spinwave pet upside down.
      Ask FixBot
    2. Bissell Spinwave Pet Battery Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove both screws.
      Ask FixBot
    3. Bissell Spinwave Pet Battery Replacement: step 3, image 1 of 2 Bissell Spinwave Pet Battery Replacement: step 3, image 2 of 2
      • Remove the two secondary brushes.
      Ask FixBot
    1. Bissell Spinwave Pet Battery Replacement, Battery: step 4, image 1 of 2 Bissell Spinwave Pet Battery Replacement, Battery: step 4, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two screws from the battery panel.
      Ask FixBot
    2. Bissell Spinwave Pet Battery Replacement: step 5, image 1 of 1
      • Remove the battery cover.
      • If the battery cover is difficult to remove, use a spudger to gently lift the edge before attempting again.
      • Pick up the battery from the compartment.
      Ask FixBot
    3. Bissell Spinwave Pet Battery Replacement: step 6, image 1 of 2 Bissell Spinwave Pet Battery Replacement: step 6, image 2 of 2
      • Squeeze the tab against the connector and pull the two sides apart to disconnect the battery.
      Ask FixBot
Steven Schayer
293 Reputation
2 Guides authored
UMass Dartmouth, Team 3-5, Santin Fall 2024 Member of UMass Dartmouth, Team 3-5, Santin Fall 2024
UMASSD-SANTIN-F24S3G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 52
All Time: 471
