Up to 20% off select tools
Bissell SmartClean 1605 Front Cover Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
89
All Time:
724
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide is for removing the front cover of your device. If you need to replace or clean the sensor or it's wiring you will need to remove this cover.
    1. Bissell SmartClean 1605 Front Cover Replacement, Front Cover: step 1, image 1 of 1
      • Power off your device
      Ask FixBot
    2. Bissell SmartClean 1605 Front Cover Replacement: step 2, image 1 of 1
      • Flip your device and unscrew the marked screws using a phillips screwdriver.
      Ask FixBot
    3. Bissell SmartClean 1605 Front Cover Replacement: step 3, image 1 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 3, image 2 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 3, image 3 of 3
      • Gently pry off the top half of the front cover
      • Remove the wires from the socket.
      • Don't pull the wires too hard, they can become disconnected from the plastic plug.
      Ask FixBot
    4. Bissell SmartClean 1605 Front Cover Replacement: step 4, image 1 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 4, image 2 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 4, image 3 of 3
      • Once the top cover is removed, pry off the bottom casing.
      Ask FixBot
Author
with
Michael Derrenbacher
104 Reputation
1 Guide authored
Cal Poly, Team S7-G4, Banghart Fall 2017 Member of Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 89
All Time: 724
