Introduction
This a step-by-step guide to show how to replace the power switch on your Bissell CleanView Compact 3508. The power switch is the component under the red lever that turns your vacuum on/off.
With the vacuum in an upright position, press the latch on the rear of the spine to remove the handle from the vacuum.
Push the button on the canister to remove it from the spine.
Set the canister to the side.
