Bissell Air180 Fan Replacement
  1. Bissell Air180 Fan Replacement, Air Filter: step 1, image 1 of 2 Bissell Air180 Fan Replacement, Air Filter: step 1, image 2 of 2
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
    Ask FixBot
  2. Bissell Air180 Fan Replacement: step 2, image 1 of 1
    • Grab the sides of the filter and pull it up.
    Ask FixBot
  3. Bissell Air180 Fan Replacement: step 3, image 1 of 1
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
    Ask FixBot
  4. Bissell Air180 Fan Replacement, Power Supply: step 4, image 1 of 1
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
    Ask FixBot
  5. Bissell Air180 Fan Replacement: step 5, image 1 of 3 Bissell Air180 Fan Replacement: step 5, image 2 of 3 Bissell Air180 Fan Replacement: step 5, image 3 of 3
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
    Ask FixBot
  6. Bissell Air180 Fan Replacement, Control Buttons: step 6, image 1 of 3 Bissell Air180 Fan Replacement, Control Buttons: step 6, image 2 of 3 Bissell Air180 Fan Replacement, Control Buttons: step 6, image 3 of 3
    • Pry off the top vent, separating it from the fan and motherboard housing.
    Ask FixBot
  7. Bissell Air180 Fan Replacement: step 7, image 1 of 2 Bissell Air180 Fan Replacement: step 7, image 2 of 2
    • Pry the button control panel up and away from the rest of the device using a spudger.
    Ask FixBot
  8. Bissell Air180 Fan Replacement: step 8, image 1 of 2 Bissell Air180 Fan Replacement: step 8, image 2 of 2
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
    Ask FixBot
  9. Bissell Air180 Fan Replacement, Fan: step 9, image 1 of 3 Bissell Air180 Fan Replacement, Fan: step 9, image 2 of 3 Bissell Air180 Fan Replacement, Fan: step 9, image 3 of 3
    • Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
    • Remove the two 11 mm screws using a Phillips #1 screwdriver.
    • Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
    Ask FixBot
  10. Bissell Air180 Fan Replacement: step 10, image 1 of 2 Bissell Air180 Fan Replacement: step 10, image 2 of 2
    • Flip the motherboard and fan housing back over and pull the fan up separating it from the rest of the device.
    Ask FixBot
Aleah Ramos
533 Reputation
5 Guides authored
UMass Dartmouth, Team 3-4, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-4, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G4
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 38
All Time: 595
